Hi, Can anyone suggest how to apply percentage based allocation logic in Cogos Tm1?
(User hase to put target amount that need to get allocated on certain allocation Percentage)
Thanks in advance.
Percentage based allocation
rmackenzie
Re: Percentage based allocation
One fairly standard approach is to have a second cube holding the percentages that is used in a cube rule:
Note in this abstract example, '$ allocated' and '$ before allocation' are elements in the measure dimension of 'Cube1'. Note that 'Cube1' and 'Percentage Lookup' have a shared dimension which facilitates the look-up. The feeder would be:
I wonder if you've read these guidelines regarding asking questions on the forum. To get a better answer to your question, you should supply more information regarding the set-up of your cubes (including names, dimensions, dimension order etc), any rules you've already written, and a brief explanation of the business problem. As it stands, you've got a very general answer to a very general question. HTH.
['$ allocated'] = N: DB ( 'Cube1', !Dimension1, !Dimension2, !Dimension3, '$ before allocation' ) *
DB ( 'Percentage Lookup', !Dimension2, 'Percentage' );Code: Select all
['$ before allocation'] => ['$ allocated'];Robin Mackenzie
