Perspective Error on CITRIX
kkmk
OLAP Product: IBM Cognos TM1
Post by kkmk »
We are trying to configure TM1 Perspective in CITRIX Meta Frame and while loading it shows only XXX in the Menu bar.
Any help to resolve this issue?
Thanks in advance
KKMK.
Paul Segal
Version: TM1 11 and up
Re: Perspective Error on CITRIX
Post by Paul Segal »
Hmmm, the last metaframe presentation server version went end of life at the end of 2009, as far as I can see.
I'm afraid I don't have a solution to your problem, but a Citrix upgrade might be a good idea.
Paul
cgaunt
Version: 9.0 SP3 9.5.1 10.1.1
Excel Version: excel 2010 2007 2003
Post by cgaunt »
I would look to rename the TM1ribbon.xlam file on the citrix boxes. This will take away the ribbon menu, but allow you to see the old style menu under the add-ins. You may have a compatibility issue, but its hard to tell as ythe version on your profile dont match what you are seeing on the screenshot.
kkmk
Post by kkmk »
Thank you for your suggestions. This issue has been resolved by upgrading local client tool with Citrix online plugin 12.3.0.8.
KKMK
