After the automatically update for IE last night, I found at least 2 problems with TM1web running on IE10:
1. Image/Picture on web sheet can not be printed in IE10.
2. Data columns cannot align with the column headings even in 100% zoom size.
These are critical issues. Has anyone noticed? Is there any solution?
Tm1web problem with IE 10
- Version: 2.0.5
Re: Tm1web problem with IE 10
IE 10 isn't a supported browser yet. I'm not aware of any workarounds
http://www-01.ibm.com/support/docview.w ... wg27036005
Have you tried using developer mode and changing browser version down to 9 from there?
- Version: 9.5.2
- Excel Version: 2007-10
I note that your profile info says you are using v.9.4. I dont think that is compatible with IE9 let alone 10. We are on 9.5.2 and have issues where people have IE9.
- Version: Cognos TM1 10.1.1
- Excel Version: MS Excel 2010
Eventually I found that the compatible mode in IE10 can make the image rendered and align the columns well as IE9. Hopefully it helps.
Sorry about that I am now using 10.1.1AmbPin wrote:Hello,
