I am having difficulties with exporting special language characters to a flat file in a TI process. It is about hungarian characters, for example ő - no matter what I do, in the flat file I get a question mark. My best hope was this, but it made no difference:
setOutputCharacterSet (sOutfile, 'TM1CS_ISO_8859_2');
Any ideas?
Holger
SetOutputCharacterSet
- jim wood
- Version: PA 2.0.7
Re: SetOutputCharacterSet
Have you tried TM1CS_ISO_8859_16?
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Which are you using, ASCIIOutput or TextOutput?
[EDIT]
The other thing to consider is this from the TM1 Docs
[EDIT]
This argument should be indentical to the FileName argument for the TextOutput function.
holger_b
Sorry no difference, not with the codepage Jim proposed, nor using textoutput instead of asciioutput. And I made sure the filename variable is complete including path and extension...
Duncan P
Just to be clear ASCIIOutput only uses the ASCII character set - like it says on the tin. If you want anything other than US ASCII then use TextOutput.
Two option spring to mind.
- Use TM1CS_UTF8 (which I thought was the default) and which should provide a readable file
- Find out what your Windows code page is and use TM1CS_WCPnnnn where nnnn is your code page
.pk.
- Version: 9.5.2
I always use TM1CS_UTF8, works like a charm with windows editors.
holger_b
Finally it worked after I decided to move the setOutputCharacterSet function from the prolog to the data tab where the file is actually written. Apparently one must keep in mind that each tab writes a new file (or overwrites the one from the previous tab), so you need to have the code page definition there.
Thanks for your help!
Holger
Holger
fr4n3kj
- OLAP Product: IBM Cognos Analytics
- Version: 10.3.10700.60404
Thanks for the solution! I had the same problem with setOutputCharacterSet and was trying to find what is wrong and which encoding should I use. In the end it was good encoding but bad placing.holger_b wrote: ↑Mon Mar 25, 2013 2:54 pm Finally it worked after I decided to move the setOutputCharacterSet function from the prolog to the data tab where the file is actually written. Apparently one must keep in mind that each tab writes a new file (or overwrites the one from the previous tab), so you need to have the code page definition there.
Holger
It's interesting difference between setOutputCharacterSet and for example DatasourceASCIIDelimiter, which I didn't see earlier but which is kinda obvious. The first one is referring to "DataSource" and it can be applied once in the prolog and the second one is applied to output data (TextOutput) but only (as You pointed out) in one tab, because (from IBM):
The text file is opened when the first record is written, and is closed when the TurboIntegrator procedure (Prolog, Metadata, Data, or Epilog) containing the TextOutput function finishes processing.
