How did I release the tm1s.log!
The server can't be closed!
And can't savedata!
One a world,just to generate a xxx.rej file without server close.
One question About TM1
ChineseMan
- Version: 9.5.2
Re: One question About TM1
The only way to release tm1s.log is to do e save data or shut down the server.
ChineseMan
- Version: 9.5.2
Okay,thanks for your reply!lotsaram wrote:The only way to release tm1s.log is to do e save data or shut down the server.
Few supplementary suggestions:
a You should point your log directory outside your server directory. If you do that you can backup the server directory without shutting down the server (do a SaveDataAll first)
b If you want to work with the contents of the log, SaveDataAll will close the current tm1s.log, rename it with a datestamp, and open a new one. The log files are now available.
