We have a TI process that currently extracts all natural accounts entries over each month for a year from a cube view. Currently the extract includes all values, no matter if they are zero or not.
I am trying to get the output file that includes a line for the natural account for each month & full year total if there is a value somewhere in at least one month, even if it is an in & out transaction over different months, so if say, $1,000 is shown in Jul, but -$1,000 is shown in Aug, with a full year total of $0, we still need the line to appear in the extract.
I am having trouble finding how to do this, within the one TI process. I have basic knowledge of TI Processes - this process was written by an ex employee, & I am trying to modify it to get it working properly. Originally, it was only extracting natural account lines with values in them, & I have included the ViewExtractSkipZeroesSet to now include zeroes. I just need it to go that extra step!
Greatly appreciate any help on this.
Regards & many thanks
Terri
Data extract where leaf value <>0, but consol = 0
rksharmatm1
Re: Data extract where leaf value <>0, but consol = 0
If i understand correctly, you want to extract lines for months only if they have non zero values, and for total_Year - extract the line in both the cases, whether it has 0 or any value.
create the extract view as you are doing it now
just before exporting the data into file, put a IF condition (assumption that months elements, Total_Year element is in same dimension)
--> check if it is month (leaf level elements), then extract only those which have measure value <>0 against them
--> For total_year ( consolidation element), no condition, every line will be exported into file.
Hope it helps..
Hope it helps..
Think it sounds like you are using an asciioutput() on the data tab of your process?tez wrote:Hi
Terri
In order to show:
Months where the value <> 0
Full Year where the value of any child month <> 0
I would simply have ViewExtractSkipZeroesSet to 0 (i.e. show all rows regardless of whether there is a value or not)
Then add the following at the top of your data tab (and/or metadata if you are doing similar things in there)
If ( DTYPE ( 'Month', vMonth ) @= 'N' );
If ( Value <> 0 );
nSkip = 0;
Else;
nSkip = 1;
EndIf;
Else;
nSkip = 1;
iCount = 1;
iMax = 12;
While ( iCount <= iMax );
sMonth = ElComp ( 'Month', vMonth, iCount );
If ( CellGetN ( sCub, v1, sMonth, v3, v4, v5 )<>0);
nSkip = 0;
iCount = 12;
EndIf;
iCount = iCount + 1;
End;
EndIf;
If ( nSkip = 1 );
ItemSkip;
EndIf;sCub is the cube in your data source.
vMonth is the variable of your month dimension
v1, v3, v4, v5 are the other variables (assuming its a 5 dim cube and month is dim 2)
HTH
Depending on the sparsity in the cube this could be quite expensive, time-wise. Another option would be to add another element to the measure dimension, called ABS_Amount and calculate it as ABS(RegularMeasure). Build your view, zero-suppressed, on this measure. Then in the data tab have a CellGetN formula to get the original measure to output.declanr wrote:I would simply have ViewExtractSkipZeroesSet to 0 (i.e. show all rows regardless of whether there is a value or not)
tez
- Version: 10.2.1 FP3
- Excel Version: 2013
Thanks for all your posts....I've tried some solutions & they don't seem to be working (could be because of my lack of knowledge though)!
Just to clarify, I need an asciioutput txt file, comma delimited, that gives me a line for each natural account number, along with Jul Amt, Aug Amt, Sep Amt......Jun Amt for the financial year if any of those months contain a value <> 0. If only one month has a value <> 0, I need the zeros from all the other months also showing in the extract. The only time a natural account number will not appear in the extract is when all months for that account = 0.
The heading of the txt file currently looks like:
"ACN","01/AMT1","02/AMT1","03/AMT1","04/AMT1","05/AMT1","06/AMT1","07/AMT1","08/AMT1","09/AMT1","10/AMT1","11/AMT1","12/AMT1","FullYear"
where ACN is natural account number, & then the values for each month. I had put the FullYear on the end to test that it was bringing through ACNs where the FullYear = 0.
I'm not sure if this changes some of your solutions you have given me, or has given you some extra info that helps.
Many thanks
Terri
Many thanks
Terri
tez
Ok, I worked it out! I have added in the code after the extract of all values & before the asciioutput line, it will export all month values for only those natural account numbers that have a value in any AMTxx column <> 0.
Thanks for all your ideas & help.
Terri
if(AMT01<>0 % AMT02<>0 % AMT03<>0 % AMT04<>0......)Thanks for all your ideas & help.
Terri
