Hi Guys,
Just a question. I deployed an approval application. The source view has 98 percent rule-calculated values coming from the other cubes.
The view works fine in Connected Mode even if I suppress zeroes only for the rows. Records with values are shown.
But when I try to open in Distributed Mode, no record is shown. This is the same zero-suppression for rows only.
Even if there are rows that have values (rule-calculated), they are not shown in the slice. This is when all my input measures are all empty at the start. But when I put values to the input measures in Connected Mode, then go back using the Distributed mode, the rows are then visible.
What I am thinking is to put flag values for rows that have rule-calculated values upon uploading of data in the source cubes.
But is it the way it is?
Thanks in advance for helps.
Bunch
Do feeders work in distributed mode?
- Version: 10.2.2.x
- Version: 10.2
Re: Do feeders work in distributed mode?
Do your feeders contain references to attributes or other cubes?
I believe the process which downloads the local server in distributed mode will miss these dependencies. Try manually defining the dependencies using a TI.
- Version: 10.2
Or you could probably add the cube dependencies required in the manual dependencies folder of your application in Performance Modeler, like you would if you adding websheets to an application.
- Version: 10.2.2.x
Hi WhiteJ_D,
You are correct! Thanks for the answer. I actually used attributes in my feeders. I deployed them as part of the application. And it's working now. Thanks.
Bunch.
Bunch.
