55: Object Not Found for TM1 Websheet
appleglaze28
- Excel Version: 2003
I was wondering if anybody has encountered this problem...some of my websheet are working and i can open and work on them but there are some that encounter an error and a dialog box pops up and says "55 Object Not Found".
- USA11SF
- Version: 10.2.2 FP2
- Excel Version: Excel 10
Re: 55: Object Not Found for TM1 Websheet
Did you solve this issue yourself? Solution?"
Soldier, Sailor, Airman, Marine <<<)
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
Try reloading the navigation tree and open the web sheet again.
It is possibly the case that you have deleted and then re-Uploaded a web sheet using an existing name. (Which seems to be a requirement these days as Updating websheets gives me a pile of garbage when I reopen them.) The issue is that the code behind the navigation tree is still looking at a link to the old file, which no longer exists. Reloading the tree refreshes the XML so that it now looks at the new file.
Andy Key
