I need some advice on where I am going wrong with a re-write of an existing rule.
The current rule references the 'Amount' measure & works just fine.
The issue is the client does not want to mix a rate with the 'normal' dollar amounts as you cannot sum these together logically.
My solution was to create a new measure called 'Rates' & reference the rule to this new as below;
Well it doesn't work, I'm getting a 0 value returned. I'm lost on where I am going wrong, sorry if its bleeding obvious, I'm a newbie to Tm1.
The Contribution Margin is a C element made up of 3 N elements.
The Contribution Margin rate is a C element, but I did this to avoid writing feeders , i.e. I added a feeder as a child; "tonnes despatched''.
I'm using 9.5.2, 64bit, Win7, excel 2010
Any advice would be very appreciated.
Maznik
I am using 9.5.2, 64bit, Win7
Reference existing Rule to a new measure does not work.
Re: Reference existing Rule to a new measure does not work.
That's because of this little snippet of codeMaznik wrote:Well it doesn't work, I'm getting a 0 value returned.
IF(['Tonnes Despatched'] = 0,-
Maznik
- Version: 9.5.3
Thankyou very much Tomok, you saved me from going just a little bit more insane
