I'm using oracle 10g and TM1 10.1.1.
Made a string param, but it doesn't return any row when I click preview button.
SELECT INVOICE_DT, CUST_CODE, PLANT_CODE, PRDTP, REV_INVOICE
FROM ODS_TABLE
WHERE INVOICE_DT = '%pStartDate%'
When I replace '%pStartDate%' with '24-SEP-2012', it works fine.
INVOICE_DT field is Date type. and the parameter value I have is '24-SEP-2012' because '09/24/2012' doesn't work. There are also existing records.
Is there something wrong in my syntax?
Thanks very much
Bunch
Oracle Date Parameter in TI doesn't work
bunchukokoy
- Version: 10.2.2.x
bunchukokoy
- Version: 10.2.2.x
Re: Oracle Date Parameter in TI doesn't work
Eow. Stupid mistake.
Should be '?pStartDate?' instead of '%pStartDate%'
Thanks.
Thanks.
