Copy one cell via vb
pmakulski
Version: 9.5.2
Post by pmakulski »
Sorry, I haven't done a search of the forum. I wouldn't even know how to compose a search argument.
I made a quick slice report that has two adjacent columns.
Column C = DBRW($B$1,$A7,"Process Description")
Column D = DBRA("ExpenseProd:}Processes",A7,"Description")
(Basically, I'm moving the values of an attribute to a cube)
I want to copy the values in column D to column C
If I do a single cell manually (copy D, paste as values into C) it works. The value goes into my cube.
I tried recording this as a key stroke macro, but it just replaces the formula in column C, and it doesn't go into my cube.
Here are my two failed attempts:
Attempt 1
Dim MyCell As Range
Set MyCell = ActiveCell
MyCell.Select
Selection.Copy
MyCell.Offset(0, -1).Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
MyCell.Offset(1, 0).Select
Attempt 2
Dim MyCell As Range, MyString As String
MyString = MyCell.Value
MyCell.Offset(0, -1).Value = MyString
Re: Copy one cell via vb
Why don't you just use DBSA, DBSW or DBSW formulas in Excel? No need for VBA at all really. Why reach for the sledgehammer when you already have a hammer and its all you need?
Edit corrected the damned spell checker that corrected VBA to "GB a" but I see you understood anyway!
pmakulski
Version: 9.5.2
Post by pmakulski »
Well how cool is that!
I've never used the DBSS function before.
I must have seen it since I've read the reference guide cover to cover umpteen times, but I never realized that that is what it was used for.
So I've tried it, it works.
Per my example in column E I put:
=DBSS( D7, $B$1,$A7 , "Process Description" )
then copied this formula to the lines that needed it.
Hurrah!
Thanks for your help.
