TM1 server up but I can not login server
Aysun
Post by Aysun »
I have two machine.There is Tm1 server installation in at x machine and Tm1 architect installation in at y machine.
So I want to connect servers in x machine from y machine.I set Admin Host = x machine In TM1 Architect ->File->Options .
So I see the servers but when I click the server to login,I dont get the Server login screen.
Thanks for help.
Re: TM1 server up but I can not login server
For the server, what security mode are you running? (the IntegratedSecurityMode parameter in the TM1S.cfg file). It sounds like you could have it set to something other than native TM1 security and then haven't done all the other necessary configuration steps. Also, you say "servers", as in more than one. Did you set them to use different ports? (the PortNumber parameter in TM1S.cfg).
Aysun
Post by Aysun »
You mean that I have to change security mode in TM1 config file.The standard security mode is 1.So I set the security mode 2(This mode allows you to switch back and forth between integrated login and native Cognos TM1 security)?
'For the server, what security mode are you running? (the IntegratedSecurityMode parameter in the TM1S.cfg file). It sounds like you could have it set to something other than native TM1 security and then haven't done all the other necessary configuration steps. Also, you say "servers", as in more than one. Did you set them to use different ports? (the PortNumber parameter in TM1S.cfg).'
