Error Forming Tuple Expression
aking
Excel Version: 365
Post by aking »
Hey guys, I'm getting an error I haven't seen before and I'm hoping someone can shed some light on it.
I'm trying to attach this MDX query to a time Dimension.
{FILTER( {TM1SUBSETALL( [Time] )}, [Time].[Month] <> "")}
The attribute exists as a text attribute, and some of the elements have data in the attribute but not all. The message I get is:
I've tried to copy the expression into the window, I've tried recording a similar expression, and I've tried using a process to attach the expression. All methods give me the same error.
The dimension has an alternate Hierarchy for YTD rollups, could this be causing it?
Thanks for any Insight.
Martin Ryan
Re: Error Forming Tuple Expression
Post by Martin Ryan »
My guess is that Month is a reserved word. Try another name for your attribute.
Jodi Ryan Family Lawyer
Hello Martin
It works fine (though I would not use these names).
Aking: I guess some kind of ambiguity in the dimension or the rest of the model arises, such that TM1 cannot resolve the expression.
Without seeing your data directory I cannot be more specific. I cannot reproduce the behavior in a limited model.
Hello Martin
aking
Excel Version: 365
Post by aking »
Changed the Attribute name to frequency and it seems to be working fine now.
Thanks for the help.
Most probably because you have that attribute name somewhere else in the model.
Please do not use reserved functions in your object names.
