Greetings!
I am exploring data spreading in TM1 and finding what a powerful set of tools it is. One question I have concerns relative proportional spreading.
I understand how to apply 'RPS' manually but it appears there is a shortcut for it, in the form RP..
As there are logically many parameters to the command (reference cube, cell etc), I was intrigued to see how this could be codified as shortcut keystrokes. I could find no answer in the documentation, but did discover that, having performed one manual RPS upon a concolsidate cell, I could type "RP+500" in the same cell and this would perform as expected, i.e. add 500 in the same 'RP'
Does anyone have any information as to whether relative proportional spreading can be applied entirely by shortcut keystrokes?
Many thanks for any help.
Relative Proportional Spread Codes
iansdigby
- Version: 9 + 10 + Plan An
- Excel Version: All
- jim wood
- Version: PA 2.0.7
Re: Relative Proportional Spread Codes
You do it via TI process and assign the process to a TM1 Action button. Not quite what you're after I know.
Gregor Koch
- Version: 9.0 and up
- Excel Version: 2007 and up
I guess the reasoning why the RPS is only available through the context menu is that compared to 'simple' spreads like Proportional Spread you need to provide the details (possibly another cube) of what you want to base your spread on.
The list of shortcuts can be found in the documentation.
Btw, afaik Proportional Spread is the only one available in TI.
