Hello Experts,
Since, couple of days, i'm facing problem with Turbo Integrator process while creating New Dimension (eg: Products Dim) by taking source as .csv file. So, after configuring Data source and variables, In Maps tab under Dimension, i'm not able to find the this new .csv Dimension name i.e Products.
I've saved "Products.csv" file under this path: C:\Program Files\cognos\TM1\Custom\TM1Data\TI_Data
I'm using Cognos TM1 9.5.2 version, installed TM1 data server and Admin host on single machine (Win Xp OS) for Demo purpose.
If any one can help me on the above regards would be highly appreciable. Please do the needful.
Thanks in Advance.
Madhu
Not able to find Dim Name of .csv in TI under Maps tab
- OLAP Product: Oracle
- Version: 9.4.1
Re: Not able to find Dim Name of .csv in TI under Maps tab
That's because if you are creating a new dimension the name can't be "found" in the maps tab, you have to type it in yourself in the box for dimension name.
- Version: 9.4.1
Hi Tomok,
Thanks a lot..!! for your needful help to continue my practice with Cognos TM1. Its working perfect.
Off course, i'm working as Cognos Developer, but want to learn cognos TM1 just to upgrade my self in future on TM1.
And, I'm always be in need of small tips and help wherever I struck in between while practicing Cognos TM1.
Thanks once again for your kind and needful help.
Madhu
Madhu
