Clear Cube data partially based on dimensional values
LoganNSE
Version: 9.5.2
Excel Version: 2003 2007
Post by LoganNSE »
We have a requirement to clear/delete cube or dimension partially via TI - Cube have 3 dimensions Code, Item_nos and Measures.
Code - 01, 02, 03..99
Item_nos - 01_a1, 01_a2, 02_a1, 02_a2,...etc
Measures - m1, m2, m3, ...m123
REFRESH: On setting parameter pCode=01 in TI, we need to load new values for 01 i.e. delete item_nos 01_a1 & 01_a2 for code 01 for all measures and need to re-load them again. DimensionElementComponentDelete out of Item_nos (01_a1 & 01_a2 are child to 01) removes the entry in dimension and Cube however on adding 01_a1 again, I can see old data populated - I knew that the old data was there however I am not sure how to clear it out just for Item_nos 01_a1 & 01_a2. Can anyone guide me to clear Cube data for 01_a1 & 01_a2 if Code=01 was chosen (02_a1 & 02_a2 if Code=02 was chosen) for all measures?
NOTE: ViewZeroOut or ClearCubeData or CubeDestroy cannot be used as they will wipe out/delete whole Cube.
Searched forum however I am unable to find similar to this, please direct me if it has been already answered.
Happy Holidays!!!
Logan
Re: Clear Cube data partially based on dimensional values
LoganNSE wrote: NOTE: ViewZeroOut or ClearCubeData or CubeDestroy cannot be used as they will wipe out/delete whole Cube.
As the name suggests, VIEWZeroOut zeroes out a VIEW, not the entire cube.
- Create subsets for each dimension that you want to select elements from (SubsetCreate);
- Assign the elements that you want to clear to those subsets (SubsetElementInsert);
- Create a view (ViewCreate and the three ViewExtractSkip functions);
- Assign the subsets that you have created to the view (ViewSubsetAssign);
- Pass the name of the view to ViewZeroOut.
You'll find all of the relevant functions in the Reference Guide, an on-line link to which you'll find in the FAQ thread.
Martin Ryan
Post by Martin Ryan »
Plus a small example and some discussion of dates here: http://www.tm1forum.com/viewtopic.php?f=3&t=8248
Jodi Ryan Family Lawyer
LoganNSE
Version: 9.5.2
Post by LoganNSE »
Hi Alan/Martin,
Thanks a lot for your time and inputs - it worked, example mentioned in the link was really useful and I replicated part of it.
1. Create temp view/subset (ViewCreate & SubsetCreate)
2. Loop through the dimension and add item_numbers to temp subset (SubsetElementInsert)
3. Assign subset to the view (ViewSubsetAssign)
4. Zero out the view (ViewZeroOut)
5. Finally delete both the view and subset (ViewDestroy & SubsetDestroy)
Logan
