EMail Notification
- Version: 10.2
- Excel Version: 2013
EMail Notification
I have written a TI process for enable TM1 to send confirmation emails after executing a chore if there is any error log found. I am using VBS script (down loaded) and made some additional changes. And calling this VBS inside the TI.
I don't know where I made mistake but it is not working as expected. Sending the notification to the admins but not attaching the multiple error files.
I think i am making mistake in the time stamp line but not sure. Any help. Thanks in advance.
Thank
kkmk
Prolog:
# set empty string as quote char
DatasourceASCIIQuoteCharacter = '';
# set filename
sFileName = 'C:\send.txt';
# header
sHtml = '<html><head><style>.footer {font-size:11px;}; body {font-family: Calibri;font-size:11px;}</style></head><body>';
AsciiOutput ( sFileName, sHtml );
sHtml = '<table width="100%" cellspacing="0" style="border:1px solid #000000;font-size:11px;">';
sHtml = '<tr><td valign="middle" style="background-color:#999999;color:#FFFFFF;padding-left:5px;padding-right:5px;width:120px;"><strong>Notification
</stron
g></td>';
sHtml = '</tr>';
sColor = '#EEEEEE';
sHtml = '<tr style="background-color:' | sColor | ';"><td valign="middle" style="vertical-align:top;padding-left:5px;padding-right:5px;">' | pBody | '
</td>';
sHtml = '</tr>';
sHtml = '</table>';
sHtml = '<br/><div class="footer" align="left">Notifications generated from TM1, provided by <br/><img src="http://nnorsovmas082/site_logo.png" width=
"80"/></div>';
sHtml = '</body></html>';
#Setup Variables
Lastfile = '';
alllogs = '';
# Find todays date
s_TimeStamp = TimSt (Now, '\Y\m\d');
# Search the logs dir for last file
logfile = WildcardFileSearch( 'C:\Logs\TM1ProcessError_'|s_TimeStamp|' *.log', '');
ASCIIOUTPUT('c:\debug.txt' , logfile);
WHILE ( logfile @<> '' );
logname = 'C:\Logs\' | logfile;
alllogs = logname | ' ; ' | alllogs;
Lastfile = logfile;
logfile = WildcardFileSearch( 'C:\Logs\TM1ProcessError_'|s_TimeStamp|'*.log', '');
END;
# set filename
pAttachFile = alllogs;
EPILOG
sSender = 'sample@domain.com';
sSMTPSvr = 'exchgdomain.com';
IF( pAttachFile @<> '' );
arguments = 'CScript C:\sendMailOther.vbs '|sSMTPSvr |' ' | sSender | ' "'|pRecipient|'" "'|pSubject|'" "'
| sFileName | '" "' | alllogs | '"';
ELSE;
| sFileName | '"' ;
ENDIF;
EXECUTECOMMAND(arguments ,1);
ASCIIOUTPUT('debug.csv',arguments);
SendMailOther.VBS
Dim SMTPServer
Dim SMTPPort
Dim Mail_from
Dim Mail_to
Dim Subject
Dim Body
Dim Attach
SMTPServer = WScript.Arguments(0)
Mail_from = WScript.Arguments(1)
Mail_to = WScript.Arguments(2)
Subject = WScript.Arguments(3)
Body= WScript.Arguments(4)
if WScript.Arguments.Count = 6 then
Attach= WScript.Arguments(5)
end if
set imsg = createobject("cdo.message")
set iconf = createobject("cdo.configuration")
Set Flds = iConf.Fields
With Flds
.Item("http://schemas.microsoft.com/cdo/config ... /sendusing") = 2
.Item("http://schemas.microsoft.com/cdo/config ... smtpserver") = SMTPServer
.Update
End With
With iMsg
Set .Configuration = iConf
.To = Mail_to
.From = Mail_from
.Subject = Subject
.HTMLBody = readFile(Body)
if Attach <> "" then
a= Split(Attach, ";")
for each x in a
.AddAttachment x
next
end if
.fields.update
.Send
End With
set imsg = nothing
set iconf = nothing
function readFile(sPath)
const forReading = 1
dim objFSO, objFile, sData
set objFSO = createobject("Scripting.FileSystemObject")
set objFile = objFSO.openTextFile(sPath, ForReading)
sData = ""
do until objFile.atEndOfStream
sData = sData & objFile.readLine & vbCrLf
loop
objFile.close
set objFile = nothing
set objFSO = nothing
readFile = sData
end function
Thank
kkmk
Prolog:
# set filename
# header
</stron
g></td>';
sHtml = '</tr>';
sColor = '#EEEEEE';
</td>';
sHtml = '</tr>';
sHtml = '</table>';
"80"/></div>';
#Setup Variables
Lastfile = '';
alllogs = '';
# Find todays date
Lastfile = logfile;
END;
# set filename
EPILOG
ELSE;
| sFileName | '"' ;
ENDIF;
SendMailOther.VBS
Dim SMTPServer
Dim SMTPPort
Dim Mail_from
Dim Mail_to
Dim Subject
Dim Body
Dim Attach
end if
With Flds
.Update
End With
With iMsg
.To = Mail_to
.From = Mail_from
.Subject = Subject
for each x in a
.AddAttachment x
next
end if
.fields.update
.Send
End With
set imsg = nothing
set iconf = nothing
sData = ""
loop
objFile.close
readFile = sData
end function
- Martin Ryan
- Version: 10.1
Re: EMail Notification
It's very hard to determine what a batch or script file is doing from TI.
To debug, try spitting out the command that you're executing to an error log (ItemReject(arguments)), then copy and paste that into the command line to see if it works as you expect.
Also I note you're using a C:\ reference, I presume you're aware that this will be looking on the server's C:\, not your own?
Martin
Martin
Jodi Ryan Family Lawyer
- jameswebber
- OLAP Product: Cognos Express 10
- Version: CE 10.1.1
That script will not handle multiple attachements
By the way a great use of this is in the StartupChores=<chorename> Parameter in the later versions of TM1 to let you know tm1 is loaded
try this vba:
here is the pro
chnage <location> to you logs location
Epilog
try this vba:
im SMTPServer
Dim SMTPPort
Dim Mail_from
Dim Mail_to
Dim Subject
Dim Body
Dim Attach
' JW20121002 Added check for multiple attachements
end if
With Flds
.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = SMTPServer
.Update
End With
With iMsg
.To = Mail_to
.From = Mail_from
.Subject = Subject
for each x in a
.AddAttachment x
next
end if
.fields.update
.Send
End With
set imsg = nothing
set iconf = nothing
sData = ""
loop
objFile.close
readFile = sData
end function
here is the pro
## This process is designed to be tacked onto the end of the overnight jobs to email errors so we can investigate
### Setup variables
Lastfile = '';
alllogs = '';
s_TimeStamp = TimSt (Now - 1, '\Y\m\d');
# Find todays date (yesterdays)
#s_TimeStamp = TimSt (Now - 1, '\Y\m\d');
logfile = WildcardFileSearch( 'C:\<location>\TM1ProcessError_'|s_TimeStamp|'*.log', lastfile);
logname = 'C:\<location>\'|logfile;
alllogs = logname | ';' | alllogs;
Lastfile = logfile;
END;
# set filename
# Could Debug to a file using this
ASCIIOUTPUT('c:\<location>\Debug\XEmailErrorLogs_asci.txt', alllogs);
sFileName = 'C:\sent.txt';
# header
sHtml = '<tr><td valign="middle" style="background-color:#006400;color:#FFFFFF;padding-left:5px;padding-right:5px;width:120px;"><strong>Error Logs
</strong></td>';
sHtml = '</tr>';
sColor = '#90ee90';
</td>';
sHtml = '</tr>';
sHtml = '</table>';
sHtml = '<br/><div class="footer" align="left">Notifications generated by \Custom\<location> and XEmailErrorLogs Process<br/></div>';
Epilog
#Get Servername
sServername = CellGetS(<cube location>);
sSender = sServername | '@<server>';
sSMTPSvr = '<smtp server>';
#Only Email if there are log files
arguments = 'CScript "C:\<location>\sendMailOther.vbs" '|sSMTPSvr |' ' | sSender | ' "'|pRecipient|'" "'| sServername |pSubject|'"
"'| sFileName | '" "' | alllogs | '"';
ENDIF;
#For Debug
ASCIIOUTPUT('C:\<location>\Debug\xEmailErrorLogs.csv',arguments);
- Version: 10.2
Thank you Martin and James, let me try your suggestions.
kkmk
kkmk
- Version: 10.2
Hi James,
Could you please tell me what is the value for sServername variable. ?
kkmk
kkmk
- Harvey
- Version: TM1 8.3 onwards
- Excel Version: 2003 onwards
Flow has a product called Flow Responder, which allows you to send emails from TI in a much simpler and more robust way. If you want to try it out, let me know (via PM or team@flowolap.com) and I'll hook you up.
- jameswebber
I have created a sting attribute in my assumptions cube for my tm1 server name
I can then look this up so that the same code works in dev and prod as log as this variable is updated.
Hope that helps
#Get Servername
sServername = CellGetS('Assumptions','No version','No Year','Full Year','WindowsServerName');
Hope that helps
- Version: 10.2
Thank you James. Everything working fine.
kkmk
kkmk
- jameswebber
Great, glad you got it sorted
- Version: 10.2
I have scheduled a chore for email notification after all the other chores executed. It is working fine. Once again thanks to James.
But there is an another requirement that I have to schedule it after each chore executed. Could you help me with the steps to do this?
Thanks in advance.
KKMK
Thanks in advance.
KKMK
- jameswebber
- Version: 10.2
The email notification process written in TI is no longer working, because we are no longer using exchange server since we’ve moved to Office 365, and using cloud servers for send and receive emails.
Is there any other alternate to re-enable our email notification from cloud servers?
Thanks in advance,
kkmk
Thanks in advance,
kkmk
- jim wood
- Version: PA 2.0.7
Did you try searching on google for public SMTP servers that you can use? I know in the past we have used a Microsoft one.
Shop at Amazon
Shop at Amazon
- jameswebber
Looks like you will need to setup a smtp relay
http://support.microsoft.com/kb/2600912
or modify the vb code to use the TLS Encryption method
http://www.configureoffice365.com/confi ... d-devices/
However it doesn't look like the schema this is using (http://schemas.microsoft.com/cdo/configuration) supports TLS encrpytion, it does support SSL
http://msdn.microsoft.com/en-us/library ... g.80).aspx
- OLAP Product: TM1 Web, Excel and Contributor
- Version: 9.5.2
- Excel Version: 7.0
Has anyone change this code to be Outlook 2010 compliant now that CDO is unsupported ?
- Version: 9.5.2
I set up the TM1 Process, Chore and vba script but nothing worked and I wasn't getting an error so II just assumed that this wasn't going to work until I dug a bit deeper.
This is still supported and works with Outlook 2010 as cdosys is separate from Outlook.
Ensure that cdosys.dll is registered on your server and also that Default SMTP Virtual Server is setup in IIS v6 even if you are running IIS7.
See the attached technote for setting up Default SMTP Virtual Server
http://stackoverflow.com/questions/3165 ... for-abcxyz
