I am having trouble with feeders and specifically feeding a rule where the feeder value could be Zero.
Here are my rules;
SKIPCHECK;
## Variances ##
['ActvsBud%']=(['ActvsBud']\['Budget']);
['Prior']=N:DB('Reporting_MAP','Actual',!Scheme_Summary,!Accident Year,!Cover Type,!Company,!LineOfBusiness,!Nominal,ATTRS('Year',!Year,'Prior Year'),!Month);
FEEDERS;
['Actual']=>['Prior'];
In my screenshot, you can see i've got a problem whereby anything with a zero in 'September 2012 Actual' does not feed into 'September 2012 Prior'.
Am i missing something? Do I need to feed something else to enable consolidations when 'Actual' is Zero?
I assume this issue has been tackled a hundred times before and i'm just missing something obvious!
Thanks in advance,
Simon
Feeders Issue
SimonLAylett
- Version: 9.5.2
Feeders Issue
Version - 9.5.2
O/S - Windows XP Professional 2002 SP3
Excel 2007
Beginner!
Excel 2007
Beginner!
- garry cook
- Version: Various
- Excel Version: Various
Re: Feeders Issue
You just need to add an attribute for Next Year then feed Actuals into Prior for the next year such as -
['Actual']=>DB('Reporting_MAP','Prior',!Scheme_Summary,!Accident Year,!Cover Type,!Company,!LineOfBusiness,!Nominal,ATTRS('Year',!Year,'Next Year'),!Month);
so that the value in actuals feeds into the next year's prior position.
EDIT - Just noticed the feeder was feeding into Actual. Been a long day and bored waiting for a TI to finish
Paul Segal
- Version: TM1 11 and up
Re: Feeders Issue
What you're telling it is "If there's a value in Actual then feed Prior". Put that the other way, "If there's nothing in Actual, then nothing will show up in Prior", even if there is a value in Prior in the Reporting_Map cube. So the result you're getting is entirely expected.
One way of sorting it out would be to feed from the Reporting_MAP cube.
Paul
Re: Feeders Issue
Actually I would assume that the "Reporting_MAP" cube is the same cube as where the rule is written from what the OP posted.Paul Segal wrote:What you're telling it is "If there's a value in Actual then feed Prior". Put that the other way, "If there's nothing in Actual, then nothing will show up in Prior", even if there is a value in Prior in the Reporting_Map cube. So the result you're getting is entirely expected.
As per both the suggestions above you just need a "next year" attribute in your year dimension and then just feed the "prior" measure from BOTH actual and actual in the prior year. e.g.
FEEDERS;
There was also a very recent discussion on relative time offset reporting here http://www.tm1forum.com/viewtopic.php?f=3&t=8150
(Oops, only just noticed that Garry already had exactly that feeder already in the first reply.)
bhushpar82
- Version: 9.5.2,10.2.2
Re: Feeders Issue
Hi Simon,
As I see you rule:
your MSR dimension is Month, but your actual MSR dimension(Values) which you want to be in your "Prior" element should be something else. Assuming this, I am posting below reply:
so in your value dimension find an element where the value is most likely to appear, in actual. I am assuming your value/msr dimension to be "scheme_summary" and say you have three elements in it: elem1, elem2 & elem3
If you elem3 is most likely to occur
then the feeder for your above rule becomes,
Feeders;
['Prior', 'elem3']=>DB('Reporting_MAP','Actual','elem3',!Accident Year,!Cover Type,!Company,!LineOfBusiness,!Nominal,ATTRS('Year',!Year,'Prior Year'),!Month);
['elem3'] => ['elem1'],['elem2'];
I hope this helps.
As I see you rule:
Feeders;
I hope this helps.
Empty mind is Devil's Workshop, but my devils creative!!
