TM1 Documentation tool
Advertisements, add-ons and other commercial information
krishnadixit
OLAP Product: TM1, COGNOS
Version: TM1 9_5 Cognos Planning 8_4
Post by krishnadixit »
Hi CPMians,
The new Version of TM-One Documenter is released!!! TM-One DoKumentor Version 2.5
Please install this software with Admin rights
There are some enhancements & a new Module has been added:
A. Documentor Module.
  • Detailed information / summary of the cubes.
  • Cube Sizing.
  • Views info (optional).
  • Rules info (optional).
  • Detailed information / summary of the Dimensions.
  • Subsets info (optional).
  • Export TI Process list.
  • Export Dimension Attributes
  • Export Element Attributes
  • Output html file with index on left side & Object details in center pane that make easy to navigate the objects.
B. Object Dependency Checker Module. New!
  • Cube Dependency: Select a cube & see all the other cubes depending on this. (i.e. view all cubes that are been sourced by this cube.
  • Dimension Dependency: Select a DIM & see all cubes & rules using this DIM. It also displays if this Dim is being used as Picklist anywhere.
  • Element Dependency: Select an Element from Dim & see all cubes using , specifically, this element Data.
  • Subset Dependency: Select a Subset & see all the views using this subset. It also displays if this Subset is being used as Picklist anywhere.
  • Cube-Element Dependency: This is detailed level element dependency. This module checks if the data of selected element of the selected cube is being used anywhere.
You can download it from:
http://www.mediafire.com/?98q9a8tm9nu0w01
or
https://rapidshare.com/files/3609668715 ... ion2.5.rar
How to:-
Install "TM-One DoKumentor" on the workstation where TM1 server installed (with Admin rights), configure it (in "Help" menu: "Congifure Application"), & use it.
Your suggestions & queries welcome. Please provide me feedback of this tool.
Re: TM1 Documentation tool
Can you please clarify whether this is in fact now a Commercial tool, as in one that you'll be expecting payment for? I haven't downloaded it to look at it and there is no description of it in either link. However if it's not a commercial product (as you indicated that the original one wasn't), the above post probably doesn't belong in Commercial. But if it is, you shouldn't have been plastering links to it through every tangentially-related post in the forum.
Post by David Usherwood »
The install dialogue says it's eval software with a cost after (I think) 2 weeks. No price visible though.
krishnadixit
Hi David,
The price discussion can done once the user is interested in buying the license.
If anybody is interested in buying, then PM me
Speaking personally, I don't think saying you are going to charge for the software without saying how much is acceptable.
David Usherwood wrote:Speaking personally, I don't think saying you are going to charge for the software without saying how much is acceptable.
Me either, but I can think of a certain big blue company which operates that way {cough}.
However what's definitely not acceptable is the plethora of other posts that were made, sometimes dredging up threads from years ago to do so, which are directly in violation of the following policy:
- If a user posts about a problem that they're having and you think that your product or service can fix it, please link them to your post in the Commercial forums. "Boosting" your product in the main forums isn't acceptable.
I'm going to go through and obliterate all of the other posts outside of this one.
krishnadixit
I am getting some mails saying the software installs & gives following error:
"Software Initialization Error!!!"
"It seems there is some Registry error".
To avoid getting this error, please install this software with Admin rights.
krishnadixit wrote:Hi All,
I did this and still it does not work.
I got into email contact with krishnadixit to try and solve it. He was very helpful but in the end it still does not work.
On the laptop of my colleague the Documenter works. Not sure if there is any difference with my laptop.
I did not know the registry of my laptop was experiencing problems but I thought I's just let others know in case they encounter the same problem.
We are fine to test it on 1 PC so I did not bother trying to find a solution.
Andy
Version: 2.05
Post by Andy »
Hi there,
is there any other documentation tool for TM1?
I tried this one, that was working, but I do not want to pay for it.
Thanks in advance.
Edward Stuart
Version: All
Excel Version: All
Post by Edward Stuart »
Hi Andy,
Most likely this is not what you are looking for but I do find it useful when talking to users about the complexity of our systems:
http://bihints.com/graphing_tm1_data_flow
Unfortunately, on our larger models you need a magnifying glass when the output is printed onto A3 paper!
Edd
