TI help
TI help
I have a dimension called “Region” which has 3 levels and
My structure got misplaced the Europe element came out of the German consolidated but Europe is there still in the German consolidation so I looked for other dimensions and like this I got it for 3 dimensions (misplaced) out of 200 dimensions so I plan to write the TI script to get the misplaced elements out of 200 dimensions so can you please help me someone what functions I should use here?.please refere the attached doc
- Doc.docx
- attached doc
- (25.95 KiB) Downloaded 459 times
Re: TI help
Well, you've had 41 hits but no answers.mincharug.shulft wrote: I have a dimension called “Region” which has 3 levels and
Somehow I doubt that's because nobody knows the answer.
I think that possibly the twin problems are:
(a) If "German" is a consolidation, I can't help thinking that "Europe" might be as well rather than being the N level element that you've shown it as being. (Meaning, in turn, that while that screen shot is a description of a problem it may not necessarily accurately reflect your problem); and
(b) You're a little light on the detail of which of these functions you have already tried. In particular the ones under the heading "Dimension Manipulation TurboIntegrator Functions".
- Version: 9.5
Re: TI help
"Europe element came out of the German consolidated but Europe is there still in the German consolidation"
I wonder if it is possible to have an N element to be parentless at the same time N element is a parent of another element ?
If Europe is still in the German consolidation, after pressing on hierarchy sort you shouldnt see Europe hanging outside the consolidation.
Will your question be something like you would like to go through 200 dimensions to find out N elements that are parentless?
Re: TI help
My emphasis added.winsonlee wrote: I wonder if it is possible to have an N element to be parentless at the same time N element is a parent of another element ?
If it is, I think that may be either one for the Bugs forum, or a revolutionary new way of creating quantum hierarchies.
Re: TI help
To find out the number of parents an element has you should use ELPARNmincharug.shulft wrote:I plan to write the TI script to get the misplaced elements out of 200 dimensions so can you please help me someone what functions I should use here?
To find out the type of the element you should us DTYPE
The TI code to bring it together is:
sDimName = 'WHATEVER_YOUR_DIMENSION_NAME_IS';
sElementName = 'WHATEVER_ELEMENT_YOU_NEED_TO_CHECK';
nParentCount = ELPARN ( sDimName, sElementName );
sElementType = DTYPE ( sDimName, sElementName );
IF ( nParentCount = 0 & sElementType @= 'N' );
# do stuff like an AsciiOutput
ENDIF;
Robin Mackenzie
Re: TI help
Thanks to all,
again i have small correction in my first posted;the misplaced element is not there in the any of the consolidated structure and when i open that misplaced element the weight its not editable that means i understood misplaced elements are corrupted.here not sure why its been corrupted (this is other question).
and i am trying to write script which can check get the all elements(DIMSIZ) and check every element whether with in the given strucure (attached Doc) if any one of the element is not comes under predefined stracture so i am taking that as misplaced element.so is please correct this codition .thanks a lot again.
belement,ename are the run time parameter i am using here
ELISCOMP(belement,ename,'Region') =0 % ELISCOMP(belement,ename,'German') =0 % ELISCOMP(belement,ename,'America') =0 % ELISCOMP(belement,ename,'Brazil') =0 % ELISCOMP(belement,ename,'Gulf') =0
- Doc.docx
- (27.11 KiB) Downloaded 385 times
- Version: 2.5 to PA
- Excel Version: Lots
Re: TI help
In general, if you are looking at the element properties and you can't edit the weighting or change the element type, click on the element name on the left hand side of the properties window first.
Having said that, if Europe does not have any parents, then having a weighting of zero is not a problem and is in no way any indication that an element is corrupt. Weightings are only applied when adding elements together in a consolidation. As Europe doesn't have any parents weighting is completely irrelevant.
Andy Key
Re: TI help
Here when i opened the element properties weight should be not editable.i did this test already.
so when you open the my attached screenshot; i want to get the elements whichever were misplaced outside my structure.can you please verify the below logic is it correct?
simply its checking for all the passing elements and whether its belongs to any one of the consolidation or nor ,if any one of element its not belngs to 5 consolidated( element2) then display/get that as the asciiout put is it correct? this Urgent help me all gentlemens
IF ( ELISCOMP(belement,ename,'Region') =0 % ELISCOMP(belement,ename,'German') =0 % ELISCOMP(belement,ename,'America') =0 % ELISCOMP(belement,ename,'Brazil') =0 % ELISCOMP(belement,ename,'Gulf') =0);
Asciioutput('test.txt',belement,ename);
Re: TI help
mincharug.shulft wrote:i want to get the elements whichever were misplaced outside my structure.can you please verify the below logic is it correct?
Reading your post, I am thinking that you want to output the elements that don't roll up to any of the consolidations. Also, I take it that an element that rolls up to 'America' won't roll up to 'Gulf'. In this case, I believe your logic is wrong because the OR-logic in the IF statement will lead to the output of an element because at least one condition will be true.mincharug.shulft wrote:IF ( ELISCOMP(belement,ename,'Region') =0 % ELISCOMP(belement,ename,'German') =0 % ELISCOMP(belement,ename,'America') =0 % ELISCOMP(belement,ename,'Brazil') =0 % ELISCOMP(belement,ename,'Gulf') =0);
E.g. New York is not in Saudi Arabia, meaning that:
ELISCOMP ( belement, 'New York', 'Gulf' ) = 0 is true
ELISCOMP ( belement, 'New York', 'America' ) = 0 is false
So the IF statement evaluates to truth because there is at least one TRUE in there, but you wouldn't output New York because it is happily rolling upto 'America'.
Perhaps you need to be using the AND operator - & - this will trap elements that are not in any of your structures.
IF ( ELISCOMP(belement,ename,'Region') =0 & ELISCOMP(belement,ename,'German') =0 & ELISCOMP(belement,ename,'America') =0 & ELISCOMP(belement,ename,'Brazil') =0 & ELISCOMP(belement,ename,'Gulf') =0);
Robin Mackenzie
