I've written a VB function that executes a TM1 process with a given name 'tm1process' , specified parameters 'parameters' (is an array), loginname 'login', password 'password'.
The function also expects that the following constant variables to be defined:
Public Const c_ServerName = "INSTANCENAME"
Public Const c_AdminHost = "SERVERNAME"
p_ExecuteTM1process 'Test process',Array('parameter1','parameter2'),'Admin','Password')
Public Function p_ExecuteTM1process(ByVal tm1process As String, ByVal parameters As Variant, ByVal login As String, ByVal password As String) As Boolean
' Auteur:
' Jan
' Parameters:
' tm1process -> Name of TM1 process
' parameters -> Array containing the parameters for the TM1process
' login -> TM1 loginname
' password -> TM1 password
' Function:
' Executes TM1 process 'tm1process'
' REMARK:
' Expects the following constants to be declared and initialized:
' Const c_ServerName 'Name TM1 server
' Const c_AdminHost 'Hostname of TM1 server
' Return:
' TRUE -> Function succeeded
' FALSE -> Function failed
On Error GoTo AfterError:
Dim nServerName As Long
Dim hServerName As Long
Dim nClientID As Long
Dim nPassword As Long
Dim Retlong As Long
Dim voprocess As Long
Dim hParametersArray As Long
Dim iparamarray() As Long
Dim nNrOfParams As Long
Dim sprocessname As String
Dim RetType As Long
Dim ErrorCode As Long
Dim nI As Integer
Dim sErrMsg As String * 100
'Connection
TM1APIInitialize
hUser = TM1SystemOpen()
If hUser = 0 Then
MsgBox ("Error opening the system")
GoTo ExitFunction
End If
'Create pool
pGeneral = TM1ValPoolCreate(hUser)
If pGeneral = 0 Then
MsgBox ("Error creating memory pool")
GoTo ExitFunction
End If
'Admin host
Call TM1SystemAdminHostSet(hUser, c_AdminHost)
Retlong = TM1SystemServerNof(hUser)
' Locate server and connect
nServerName = TM1ValString(pGeneral, c_ServerName, 75)
nClientID = TM1ValString(pGeneral, login, 75)
nPassword = TM1ValString(pGeneral, password, 75)
hServerName = TM1SystemServerConnect(pGeneral, nServerName, nClientID, nPassword)
sprocessname = tm1process
nNrOfParams = UBound(parameters) + 1
ReDim iparamarray(nNrOfParams - 1)
'For each parameter
For nI = 1 To nNrOfParams
iparamarray(nI - 1) = TM1ValString(pGeneral, parameters(nI - 1), Len(parameters(nI - 1)))
Next nI
hParametersArray = TM1ValArray(pGeneral, iparamarray, nNrOfParams)
'For each parameter
TM1ValArraySet hParametersArray, iparamarray(nI - 1), nI
Next nI
voprocess = TM1ObjectListHandleByNameGet(pGeneral, hServerName, TM1ServerProcesses(), TM1ValString(pGeneral, sprocessname, 100))
Retlong = TM1ProcessExecute(pGeneral, voprocess, hParametersArray)
RetType = TM1ValType(hUser, Retlong)
If RetType = TM1ValTypeError Then 'TM1ValTypeObject Then
'Return value is an error object
TM1ValErrorString_VB hUser, Retlong, sErrMsg, 100
Err.Raise vbObjectError + 514, , sErrMsg
Else
'Return value is a boolean value
Retlong = TM1ValBoolGet(hUser, Retlong)
If Retlong = 0 Then
Err.Raise vbObjectError + 515, , "Process generated errors" & vbCrLf & "Check log file."
Else
'Process executed successfully
End If
End If
p_ExecuteTM1process = True
ExitFunction:
'DECONNECTION
If pGeneral > 0 And hServerName > 0 Then
Retlong = TM1SystemServerDisconnect(pGeneral, hServerName)
End If
'Destruction of pool
If pGeneral > 0 Then
TM1ValPoolDestroy (pGeneral)
End If
If hUser > 0 Then
Call TM1SystemClose(hUser)
End If
Exit Function
AfterError:
MsgBox "p_ExecuteTM1process: There was an error while executing process '" & tm1process & "':" & vbCr & vbCr & Err.Description, vbCritical, "Oops"
Resume ExitFunction
End Function
Can anybody help me with this? I know it is possible but I can't seem to retrieve the location of the logfile
Thanx in advance,
Jan
