I need your help. Currently we have TM1 9.5.2 running in one server with two Xeon processors, each one with four cores and 48 GB of memory. We are migrating to a new server with 4 Xeon processors, each one with 6 cores and 80 GB of memory. Is it necessary to do any additional configuration in TM1 in order that it recognize the new settings? Or TM1 recognizes them automatically?
MIGRATION TO NEW SERVER 4 PROCESSORS
hectorfabios
- Excel Version: 2010 y 2007
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
Re: MIGRATION TO NEW SERVER 4 PROCESSORS
TM1 will automatically use all resources available on the server.
The only manual change you can (optionally) make is if you are using the MaximumCubeLoadThreads parameter in your tm1s.cfg, then you will be able to increase it on the new server.
Andy Key
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
And, if you are on Enterprise licensing basis, make sure that you have increased the PVU count!!hectorfabios wrote: Currently we have TM1 9.5.2 running in one server with two Xeon processors, each one with four cores and 48 GB of memory. We are migrating to a new server with 4 Xeon processors, each one with 6 cores and 80 GB of memory.
