Not a valid win 32 application
I have this in the epilog of a process
NumericGlobalVariable('ProcessReturnCode');
If(ProcessReturnCode=ProcessExitNormal());
ExecuteCommand('D:\ErrorEmail2.vbs',1);
Endif;
And I get a "Error: Epilog procedure line (17): %1 is not a valid Win32 application." in the message log.
The vbs file works in the command prompt but not as part of TI.
Anyone knows the solution?
Endif;
Re: Not a valid win 32 application
My guess would be that in the ExecuteCommand function you need to pass the parameter to your vb script as a string not a value.
... but also, if the process exits normally without errors why would you want to send an email notification, surely you would want to do this only in the event of a process error log being generated?
- Version: 2.x
- Excel Version: 36x
No no no...
This is not the right way to call VBScript from TI.
ExecuteCommand will need to call a exe or a cmd, bat file. It can't execute a VBS directly.
Do this instead to execute VBS:
ExecuteCommand('C:\windows\system32\cscript.exe D:\ErrorEmail2.vbs',1);
To answer lotsaram, I used ProcessExitNormal() just to make sure the email section gets called so I can test if the email gets sent out.
I changed my code as suggested by kangkc and it worked!! thanks all....
- Steve Vincent
- Version: 10.2.2 FP1
You've got to call the vbs using the command shell like kangkc said.
I think Steve refers to how to call the sending of the email - like in
http://www.bihints.com/send_email_attachments
(If Steve doesn't refer to how to make the mailing happen the link might be useful for someone who stumbles on this post via search
And kangkc might be the kc_kang credited at above mentioned link, that would explain why he knows how to get vbs-scripts running...
Oh - and because bihints tends to be unreachable exactly the moment you need it most - I attached the send-script. (And because I may not upload txt,vbs or invalid jpg I renamed it to zip, which it is - obvioously - not. rename to txt, vbs or any extension you associate with an editor capable of opening plain text format, which should be virtually anyone not limited to wysiwyg)
To quote the credits: "code from kc_kang (applix forum) and http://www.rondebruin.nl/cdo.htm"
PS.: it is definitely too hot here...
- SendMail.vbs.not.a.zip
- http://www.bihints.com/send_email_attachments :
"code from kc_kang (applix forum) and http://www.rondebruin.nl/cdo.htm" - (891 Bytes) Downloaded 798 times
- Version: 2.x
SKIPCHECK;;
['kangkc']=['kc_kang'];
FEEDERS;
['kc_kang'] => ['kangkc']
I used a fair bit of ExecuteCommand in my consultancy work involving TM1, and there are many possibilities in process automation. TI is a very dynamic and yet simple ETL tool.
FEEDERS;
In your case I would have created an alias - I really hate having hundreds of elements mirroring each other using ruleskangkc wrote:SKIPCHECK;
FEEDERS;
['kc_kang'] => ['kangkc'];
(So I could never work at government agency where one might be able to change his or her name (honestly, I have no clue how to call the place - not even in my language. But it doesn't matter) - "I'm sorry, I'm from the TM1-side, so you want to see someone from SAP; they can change your name, I can only offer you an alias")
If I had to guess (about both the language and the name) it would be "Standesamt" or in English, "Registry Office".Lukas Meyer wrote:In your case I would have created an alias - I really hate having hundreds of elements mirroring each other using ruleskangkc wrote:SKIPCHECK;
FEEDERS;
(Or, in my own case if I revert to my former Applix Forums persona, "the Project Treadstone office at CIA Langley". Although of course I don't remember any of that...)
No, it is possible to change a name in TM1... as long as you don't mind going via the old version 6, pre-alias method of exporting their personality into a text file, deleting their name, entering the new one into their ID dimension, recompiling the dimension and re-importing their personality.Lukas Meyer wrote: - "I'm sorry, I'm from the TM1-side, so you want to see someone from SAP; they can change your name, I can only offer you an alias")
Might take a while, though.
(For the technically pedantic, yes, I know that you're really deleting the old element and creating a new one rather than "renaming" the original, but in version 6 it was as close as you got to it...)
Maybe in Germany/Switzerland, in Austria "Standesamt" is only for marriage, birth registration and death registration. You could change your name at the same building you get your pass from, tough you would need to run around for ages in this building to find what you are looking for (if the ibm-page is a maze, those governmental bureaus are a maze where lots of people give you different directions, depending on how many forms you completed. At least this seems to be the same all over the world...)Alan Kirk wrote: If I had to guess (about both the language and the name) it would be "Standesamt" or in English, "Registry Office".
So in version 6 there were no personalized folders for private items? I really like this step
I think technically pedantic people don't like the idea of renaming at at - makes just problems. Aliases are nice, especially if you have them depending on time. Those crazy SAP-guys have even structures depending on time. It's not fair, they have shiny, fun toys and all we get here are sticks,rocks and bugs to play with
- Version: 2.x
Hey guys, this is meant to clarify my identity on the old Applix forum, not a real TM1 rule. /lolLukas Meyer wrote:In your case I would have created an alias - I really hate having hundreds of elements mirroring each other using ruleskangkc wrote:SKIPCHECK;
FEEDERS;
I'm sorry if I confused anyone...
As you wrote it, it wouldn't have worked anyways...kangkc wrote:Hey guys, this is meant to clarify my identity on the old Applix forum, not a real TM1 rule. /lol
If I were sorry whenever I confuse someone, I would not be able to feel sorry anymore - so better be sorry when you crash a TM1 server at the peak-usage time, or when you are unable to give advice other than "restart your TM1 server"...
- Version: 9.5.2
- Excel Version: 2007-10
kangkc wrote: ExecuteCommand('C:\windows\system32\cscript.exe D:\ErrorEmail2.vbs',1);
Hello found this post really useful, might be worth noting that if either of the paths above contain spaces you need to put both in quotes so might be best practice to do that by default, E.g.
ExecuteCommand('"C:\windows\system32\cscript.exe" "D:\ErrorEmail2.vbs"',1);
