I have tried the max function ans read this post: http://www.tm1forum.com/viewtopic.php?f=3&t=4207, but cannot manage to get this working.
I upload seconds per item for an invoice. I need to calculate adj seconds.
For the adjusted seconds I want to put the maximum seconds per item per invoice next to each item.
Item Seconds Adj Sec
A 5 7
B 3 7
C 7 7
The adjusted seconds for each item on invoice X will be 7 sec per item.
There are other dimension in cube as well but the link is invoice and item.
I have tried:
['Adj Sec']=N:MAX(['seconds']);
['Adj Sec']=N:
MAX(DB('Despatch_Stageing',!DC,!Invoice Number,!Equipment Type,!Branch,!Item,!Supplier,!Activity,'Seconds'));
['test sec adj']=N:
IF(ELLEV('Item',!Item)=0,
Max(DB('Despatch_Stageing',!DC,!Invoice Number,!Equipment Type,!Branch,!Item,!Supplier,!Activity,'Seconds')),continue);
Am I heading in the right direction or should I try something different.
I am not able to save any of these rules above.
Thank You in advance
Max Value
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: Max Value
If you are in 9.5.2 and above look at the ConsolidatedMax function. The MAX that you are using just give the maximum of two numbers.
- Version: 9.5.2
Re: Max Value
than you
will try that, but I know that this function is very resource intensive.
Re: Max Value
That is not true. It uses feeders and works from the leaf elements in the same way as normal in-built consolidation. It is very different in that respect from ConsolidateChildren
- Version: 9.5.2
Re: Max Value
that is correct. my mistake. consolidatechildren is the bugger. will never use that again.
thank you
thank you
