Cognos Express and Server 2008 R2
Stephan
Version: ALL
Excel Version: 2008
Post by Stephan »
Environment:
- Windows Server 2008 R2 SP1
- Office 2007 SP1
- Cognos Express 9.5
- IE 8 and Firefox 6
Problem:
- My install has no problems.
- At the end of the installation after clicking, Finish Launch Express Manager i receivce this message:
An error has occurred
Loading runtime handler class: com.ibm.cognos.express.module.xcelerator.XceleratorRuntimeHandler
- When I click OK, nothing happens.
- When I refresh the page, I receive this message:
Cognos Express is already initialized.
Have anyone encountered this before?
John Hammond
OLAP Product: PAW/PAX 2.0.72 Perspectives
Version: TM1 Server 11.8.003
Excel Version: 365 and 2016
Re: Cognos Express and Server 2008 R2
Post by John Hammond »
Might be your Java version - go to Sun/Oracle's site and update with the latest would be the first thing I would try.
Also IIRC we had to fiddle round with 32bit and 64bit versions to get this to work. Cant remember more than that tho.
jameswebber
Version: CE 10.1.1
Post by jameswebber »
Is your firewall open for the CE ports on the windows server... I can't remember the error message but this was and issue I had with my 2008 R2 box
Stephan
Version: ALL
Excel Version: 2008
Post by Stephan »
Thanks for the replies. Unfortunately none of this worked.
I got this from someone:
When calling a report trigger from a Web service task, the following error message may appear:
This problem is related to the replacement of the Sun Java™ Runtime Environment (JRE) by IBM Java Runtime Environment (JRE) in this release of IBM® Cognos® Express®.
To avoid this problem, modify the bootstrap_win32.xml file in the install_location\bin directory by adding the following line of code for the spawn element under <process name="catalina"> :
<param condName="${java_vendor}" condValue="IBM">-Xss512k</param>
tried this as well, but still no success.
Any other ideas?
jameswebber
Version: CE 10.1.1
Very weird,
Have you installed .net framework on your server also added the server components for it and iis?
If So I would try installing it on another server, failing that download the install files from IBM again.
Joni
Version: 9.1 9.4 9.5
Excel Version: Excel 2003
Post by Joni »
Has TM1 or an earlier version of Cognos ever been installed on this server? If so, you may need to remove any traces from the registry...
dumbomichael
OLAP Product: tm1
Post by dumbomichael »
has there been a solution to this? we have the same problem on a brand new server with cognoss express version 10.1.0
