TI Process Questions
A few questions:
Within a TI process - how can you find out the names of all cubes?
- Possible solution to look in the Data folder for all files named *.cub ?
Within a TI process - how can you find out the names of all dimensions?
Within a TI process - how can you find out which dimensions a cube is using?
Within a TI process - how can you find out which cubes use a particular dimension?
Re: TI Process Questions
nhavis wrote:A few questions:
Cubes - loop through }Cubes dimension
Dimns - loop through }Dimensions dimension
Cube/Dimn usage - TABDIM function
G
Thanks - how can I get the number of dimensions in a cube?
Just loop through the dims until you hit a blank. For example:nhavis wrote:Thanks - how can I get the number of dimensions in a cube?
SC_CUBE = 'YourCubeName';
l_Counter = 1;
While ( l_Counter <=256 );
s_DimName = TabDim ( SC_CUBE, l_Counter);
If ( s_DimName @= '');
l_NumberOfDims = l_Counter - 1;
l_Counter = 257;
Else;
l_Counter = l_Counter + 1;
EndIf;
End;
Thanks for the quick and concise replies -
How can I add in a a newline character to a string?
Eg.
string = 'Hello';
string = string|'\n';
string = string|'more';
ASCIIOUTPUT('output.txt', string);
How can I add in other special characters?
Eg.
string = 'Hello';
Use the CHAR rules function. New line is Char(10) (though you probably really want carriage return which is Char(13)). You can Google a list of ASCII codes for other characters; there are a lot of charts out there, though I don't have any bookmarked at the moment.nhavis wrote:Thanks for the quick and concise replies -
Eg.
string = 'Hello';
I see, thanks again -
Is it possible to write an output file without the quotes that ASCIIOUTPUT includes?
Is there any kind of console or substitute?
ScottW
- OLAP Product: TM1 CX
- Version: 9.5 9.4.1 9.1.4 9.0 8.4
- Excel Version: 2003 2007
ASCIIOutput and TextOutput both write comma delimited files and only output string values encased in quotes, if you want to change this see Gregor's post below
Thanks -
In regards to inserting new line characters: I tried the following and in notepad it seems not to work:
string = '123';
string = string | Char(10);
string = string | Char(13);
string = string | '456';
ExecuteCommand('notepad output.txt', 0);
output.txt contained (when viewed in notepad):
"123456"
however the newline characters were present when viewed in vim/wordpad etc.
string = '123';
"123456"
They're there in Notepad too, but the way you've output them they'll just appear as rectangular blocks representing control characters.nhavis wrote:Thanks -
string = '123';
"123456"
The usual sequence when you combine a carriage return and line feed (alias New Line) is CRLF rather than LFCR. Reverse the order so that it's
string = string | Char(10);Code: Select all
string = string | Char(13);"To them, equipment failure is terrifying. To me, it’s 'Tuesday.' "
Gregor Koch
- Version: 9.0 and up
- Excel Version: 2007 and up
If you want AsciiOutPut without quotes use function
(that's two single quotes no space)
DataSourceASCIIQuoteCharacter='';
If you want no delimiter use function
(can be changed to anything)
DatasourceASCIIDelimiter='';
If you want your output to be eg
123
789
use the above and then
AsciiOutPut('filename', '123');
AsciiOutPut('filename', '789');
Hope it helps
Gregor
123
789
Hope it helps
Gregor
