We are on TM1 10.1 FP1 version and looking to reuse the existing TM1ProcessExecute.exe and TM1ChoreExecute.exe utilities that we use on TM1 9.5.2 FP1 version. Some of the library files required to run these utilities are not available in TM1 10 version. Is there an updated version of these executables available? Or do we have a new set of libraries required to run these executables on this version? Please help.
winoth
TI Process & Chore Execution Utilities for TM1 10.1 FP1
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: TI Process & Chore Execution Utilities for TM1 10.1 FP1
The supported mechanism to run TI from the command line in 9.5.2 FP1 and above is TM1RUNTI.EXE (http://www-01.ibm.com/support/docview.w ... wg21566543). This is available in 10.1.
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
I am aware that this post is about enterprise TM1 but good to know that Cognos Express does not provide TM1RunTI.exe - at least officially...
http://www-01.ibm.com/support/docview.w ... wg21598124
- Mike Cowie
- OLAP Product: IBM TM1/PA, SSAS, and more
- Version: Anything thru 11.x
- Excel Version: 2003 - Office 365
Hi:
I didn't realize they didn't explicitly include TM1RunTI.exe with Cognos Express. That's a bit surprising.
Are you trying the executable posted here?:
http://www.tm1forum.com/viewtopic.php?f=21&t=3486
That was the overall replacement EXE I'd posted just prior to TM1RunTI being officially released. As noted in that post, it isn't getting any further development attention at the moment given IBM's Tm1RunTI offering, but should provide the same functionality that you had in TM1ChoreExecute and TM1ProcessExecute (combined into one EXE). Those older TM1ChoreExecute and TM1ProcessExecute EXEs would definitely not allow you to establish a CAM Namespace login like you'd need for Cognos Express.
Hope that helps get you a little further along.
Mike
Mike
Mike Cowie
QueBIT Consulting, LLC
