I'm using VB in order to generate integrated login and then to run a process.
The integrated login establish well, but still the process is not running (The VB finish without errors but the TM1 not showing any change in data).
I used the following code for the process:
Sub RunProc ( hPool As Long, hServer As Long)
Dim hProcess As Long
Dim voProcess As Long
Dim lReturn As Long
Dim hParamArray As Long
Dim voParamArray(0) As Long
voProcess = TM1ValString(hPool, "Save_Data" , 0)
hProcess = TM1ObjectListHandleByNameGet(hPool, hServer, TM1ServerProcesses, voProcess)
voParamArray(0) = TM1ObjectNull()
hParamArray = TM1ValArray(hPool, voParamArray, 0)
lReturn = TM1ProcessExecute(hPool, hProcess, hParamArray)
End Sub
