Manual setting new dimension with names and aliases
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
Hello again,
And again I'm trying to defeat TM1.
I have file .CSV with just 2 important columns. First is item code and thirteenth is item name. I want to create via TI process:
- New dimension;
- New elements (named 0001, 0002, etc);
- Create many aliases (ItemName + Code, Code, ... etc).
In variables tab important colums assigned to variables ElementsCode and ElementsName.
Now my code is (with cyrillyc retyped carefully to not make any typo):
#Prolog:
user.MyDimension = 'protfcp_SubsidariesAccount';
IF ( DimensionExists (user.MyDimension) = 0);
    DimensionCreate (user.MyDimension);
ELSEIF (DimensionExists (user.MyDimension) = 1);
    DimensionDestroy (user.MyDimension);
ENDIF;
DIMENSIONDELETEALLELEMENTS (user.MyDimension);
DIMENSIONSORTORDER(user.MyDimension,'','','ByInput','ASCENDING');
user.AliasName1 = 'Code';
AttrInsert ( user.MyDimension, '' , user.AliasName1 , 'A');
user.AliasName2 = 'Name';
AttrInsert ( user.MyDimension, '' , user.AliasName2 , 'A');
#Meta:
user.NewElementName = SubSt ( NumberToString ( 1000000 + DimSiz ( user.MyDimension ) + 1) , 4 , 4 );
DIMENSIONELEMENTINSERT(user.MyDimension,'', user.NewElementName, 's');
AttrPutS ( ElementsCode , user.MyDimension , user.NewElementName , user.AliasName1);
AttrPutS ( ElementsName , user.MyDimension , user.NewElementName , user.AliasName2);
Saving performs, but running process finishes with errors like: "Element 0001 not found" in line 9 of Meta tab.
Ninth string corresponds to AttrPutS function.
Finaly I got new dimension with elements 0001, 0002, etc with Aliases filled with elements pincipal names. Where am I mistaken?
Re: Manual setting new dimension with names and aliases
Your AttrPutS functions need to be moved to the Data tab.
ioscat
Post by ioscat »
Thought tabs just performes usability...
Just to explain why your initial code didn't work.
The metadata tab builds the dimension and the new elements are not available from a data perspective until the metadata completes. Attributes are data and so need to go in the data tab.
Just in case it wasn't clear...
ioscat
Post by ioscat »
thanks again,
in guide this was not clearly stated
qml
Excel Version: 2007 - 2016
Post by qml »
It is stated in the TI Guide in the following way (admittedly not really very clear):
TM1 TurboIntegrator 9.5.2 wrote:TurboIntegrator compiles a new or altered dimension only at the conclusion of the procedure in which the dimension is created or altered.
In the case of a new dimension, this means that you cannot access the new dimension (through TurboIntegrator or otherwise) until the procedure in which the dimension is created has finished processing all records in the data source. In the case of an altered dimension, this means that you cannot access any new elements in the dimension until the procedure in which the dimension is altered has finished processing.
The meaning of "procedure" here is synonymous to "advanced tab", so elements created in Metadata are only compiled and made available after all Metadata iterations have finished.
Kamil Arendt
