Counter in while loop
Michael Barker
- Version: 10.1.1
I have a large number of elements I want to add to a dimension in TI,
i.e.
DimensionElementInsert('Department','',Department_1,'S');
DimensionElementInsert('Department','',Department_2,'S');
DimensionElementInsert('Department','',Department_3,'S');
DimensionElementInsert('Department','',Department_4,'S');
DimensionElementInsert('Department','',Department_5,'S');
(etc.)
Is it possible to create a counter (i) that I can substitute into the department variables (e.g. Department_i) with a WHILE loop?
Thanks in advance.
i.e.
(etc.)
Thanks in advance.
Catherine
- Version: 10.2.2 - PA
Re: Counter in while loop
Yes, it is. That would be something like that (not tested...):
i=1;
While (i<=200);
DimensionElementInsert('Department','','Department_'|i,'S');
i=i+1;
end;
Your element names would then be:
Department_1
Department_2
Department_200
Is that what you're looking for?
HTH
i=1;
While (i<=200);
i=i+1;
end;
Department_1
Department_2
Department_200
HTH
Michael Barker
- Version: 10.1.1
Hi Catherine,
I'm referencing Department_1, Department_2, etc. directly as variables.
Enclosing them in inverted commas populates the dimension with the text within. I'm after the variables values. So I cannot use the inverted commas.
Thanks.
Thanks.
Catherine has answered the question but I think the code needs just 1 small tweak, in the case above i is a numeric term so when stating 'Department_' | i the code may not work due to i not being string as such it could simply be replaced with 'Department_' | NumberToString ( i )Catherine wrote:Hi,
i=1;
While (i<=200);
i=i+1;
end;
Department_1
Department_2
Department_200
HTH
e.g.
i=1;
While (i<=200);
DimensionElementInsert('Department','','Department_'|NumberToString ( i ) ,'S');
i=i+1;
end;
Michael Barker wrote:Hi Catherine,
Thanks.
If Department_1 and Department_2 are variables then why don't you just populate in the metadata tab with a simple
DimensionElementInsert( 'Dim', '', v1, 'S');
Or do you mean that they are the names of the variables as opposed to the variable values?
Michael Barker
- Version: 10.1.1
They are variable names. There's s lot of them. I can copy/paste the code for all of them in the metadata tab, but that just seems unnecessary.
I'm not sure I entirely understand the problem.
Could you provide an example csv of the datasource and explain what you want to be created?
Grandryjn
- Version: 9.4.1
- Excel Version: 2003
I think that you want to retrieve the variable name from the concatenation of 'Departement_' and a number i in your while.
I think that you should try the "Expand" function.
Something like that "expand('%Departement_'|numbertostring(i)|'%')" should give you the variable value.
Is that correct?
Is that correct?
Michael Barker
- Version: 10.1.1
Expand() is what I was looking for. Let me try it out.
Thanks!
Thanks!
Grandryjn
- Version: 9.4.1
Tell me if it worked
mykill
- Version: 10.2
It should be a double Expand. The inner one to get the name and the outer one to get the value.
- Steve Rowe
http://www.tm1forum.com/viewtopic.php?f=21&t=4921
A few examples here on the use of expand to manipulate variable names.
I think you only need a single expand.
Double expand is when the value you need is held in a variable that is itself the value of antother variable....
Michael Barker
- Version: 10.1.1
Thanks all, works fantastically.
WHILE()
j = NUMBERTOSTRING(i);
DIMENSIONELEMENTINSERT('Department','',EXPAND('%Department_'|EXPAND('%j%')|'%'),'S');
i = i +1
END- Steve Rowe
Except you only need on expand
DIMENSIONELEMENTINSERT('Department','',EXPAND('%Department_'| j|'%'),'S');
will work too
will work too
