I have an interesting situation,
I want to transfer data between two cubes, Cube A and Cabe B.
Cube A has 8 dimensions and cube B has 10 dimension.
One twist here is Cube A(Source cube) has a dimension name Regions with Hierarchy of
Countries > City
Cube B has a Region_Consol dimension with only Countries.
Now I want transfer data between Cube A to Cube B with TI.
I am creating a temporary view using VIEWCREATE function. as this function by default has zero and consolidation suppressed. so this will not transfer data.
If I use ViewExtractSkipCalcsSet(Cube,ViewName,0) then consolidation from all dimensions get active and though data transfer is correct I will get an error message.
A simple way to avoid this is to create a temporary subset for all dimensions and assign to this Sourceview.
I feel its a bit lengthy code. Is there any other simple way to assign only particular dimnsion with consolidtion and rest with suppression on
looking for some shortcut from TM1 gurus
Lav
