Hi Gurus!!!
We are transferring the data from Source to target cube for particular scenario, all accounts and entities for all months...
This is happening properly.
But it is observed in some of the cost centers its data is not being used for agrregation.
When we right click on the Total agrregation and select 'Check Feeders'it is saying 'some of the cost centers data is not fed'.
We want to understand why this happens and how this can be corrected under these circumstances.
Can you please your valuables suggestions or ideas...
Advance Thanks....
Appz
Feeder Problem...
Cognostm1.ibm
- Version: 9.5.1 and 9.5.2
- Excel Version: 2007 and 2010
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: Feeder Problem...
I presume from the rest of what you say that you are not using Turbo Integrator to transfer the data but that you are using a rule in the target cube to define the data for a particular scenario as coming from the source cube.Cognostm1.ibm wrote:We are transferring the data from Source to target cube for particular scenario, all accounts and entities for all months...
It would help in understanding why your feeders are not working if you could post the relevant part of the rule (at least the full statement, left hand and right hand parts, in which the DB statement occurs), and the corresponding feeder from the FEEDERS section of the rule on the source cube.
