Is there a function in turbo that brings back the name of the month (aka: "January", "February" etc.)
N
Function that brings back the name of a month
- jim wood
- Version: PA 2.0.7
Re: Function that brings back the name of a month
You have put this in the general section??? What software are you using?
- Version: 9.5.2
Ooops, you are absolutely right my bad.
I'm using TM1 version 9.0.0 but there is a possibility of upgrading to 9.5.2 if that helps
Thanks!
N
Thanks!
N
- jim wood
- Version: PA 2.0.7
Post moved to the Cognos TM1 Forum.
- jim wood
- Version: PA 2.0.7
To answer your question. There is set of time functions for rules. If you use a combination of both NOW and TIMST you'll be able to get you what you need. You'll find these functions in the TM1 reference guide in the TM1 documentation that comes with your install,
as innholtzsh wrote:Hi All,
N
TimSt( Now, '\mmm' )
- jim wood
- Version: PA 2.0.7
Thanks for clarifying that Lotsa.
- Version: 9.5.2
Thank you guys, that helps!
