Function that brings back the name of a month
nholtzsh
Version: 9.5.2
Post by nholtzsh »
Is there a function in turbo that brings back the name of the month (aka: "January", "February" etc.)
N
jim wood
Version: PA 2.0.7
Re: Function that brings back the name of a month
Post by jim wood »
You have put this in the general section??? What software are you using?
nholtzsh
Version: 9.5.2
Post by nholtzsh »
Ooops, you are absolutely right my bad.
I'm using TM1 version 9.0.0 but there is a possibility of upgrading to 9.5.2 if that helps ;)
Thanks!
N
jim wood
Version: PA 2.0.7
Post by jim wood »
Post moved to the Cognos TM1 Forum.
jim wood
Version: PA 2.0.7
Post by jim wood »
To answer your question. There is set of time functions for rules. If you use a combination of both NOW and TIMST you'll be able to get you what you need. You'll find these functions in the TM1 reference guide in the TM1 documentation that comes with your install,
nholtzsh wrote:Hi All,
N
as in
TimSt( Now, '\mmm' )
jim wood
Version: PA 2.0.7
Post by jim wood »
Thanks for clarifying that Lotsa.
nholtzsh
Version: 9.5.2
Post by nholtzsh »
Thank you guys, that helps!
