Hi to all,
I have created a slice, the usual set-up followed in Excel. To change the specific dimension, you double-click on the element (with the SUBNM formula), and the dimension window pops up.
Is it possible in VBA to make the dimension window open without a double-click, but with a single click?
Thanks in advance.
SUBNM Double-click
Michael Barker
- Version: 10.1.1
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: SUBNM Double-click
One option is to create a cell in a cube of the model that has a picklist defined on it with the dimension members you want them to choose from. Then replace the SUBNM with a DBRW on that cell. Both Excel and WebSheets will put a drop-down against the cell.
This is fine for simple short dimensions as it displays as a simple drop-down instead of the selection dialogue you get with SUBNM. However if your dimension is long or if you want to see the structure it won't be good.
Paul Segal
- Version: TM1 11 and up
This code works for me. It needs to go in the worksheet object, and you need to replace the range (or do something cleverer with it).
See http://www.tm1forum.com/viewtopic.php?f=21&t=6424 for more detail.
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
If Not Intersect(Target, Range("B2")) Is Nothing Then
Application.Run "TWEVENTER1"
End If
End Sub
Paul
As an alternative, you could use the E_PICK macro function.
Michael Barker
- Version: 10.1.1
Thanks very much.
Application.Run "TWEVENTER1" works fantastically.
