Feeder Issue
Cognostm1.ibm
Version: 9.5.1 and 9.5.2
Excel Version: 2007 and 2010
Feeder Issue
Post by Cognostm1.ibm »
Hi Gurus,
I have a feeder which doesnt seems to work correctly.
I am getting wrong totals with below one.
Rule:
[2012, 'Amount'] = N:DB('OC_ Exp_Input',!OC_Account_Rollup,!OC_Cost_Center,!OC_Entity,’2012’, !Time, 'Amount');
Feeder:
['Amount'] => ['2012'], ['Amount'];
Can you provide your valuable suggestions to fix this one...
Appz
Paul Segal
Version: TM1 11 and up
Re: Feeder Issue
Post by Paul Segal »
Cognostm1.ibm wrote:Hi Gurus,
Rule:
Feeder:
Appz
The feeder needs to go in the cube you are getting the numbers from (i.e. OC_Exp_Input), and not the cube you are writing the rule for, so that it pushes the feed (rather than trying to pull the feed as you have it here).
Paul
Cognostm1.ibm
Re: Feeder Issue
Thanks a lot for immediate response.
Could tell me what could be the right feeder for this one...
Re: Feeder Issue
In the cube OC_Exp_Input, add a feeder by typing:
['2012','Amount']=>
then hit the DB() function button and pick the needed/corresponding elements.
Close the statement with ;
Cognostm1.ibm
Re: Feeder Issue
Thanks a lot!!!
