TM1 Web Date Format
lav4you
TM1 Web Date Format
Post by lav4you »
I am facing a weird issue for TM1 Web.
I have two columns which has custom date format (c:dd/mm/yyyy;;) it works fine in cube viewer but on TM1 web format is getting lost.
It shows these field in number format and when user is trying to enter date value eg. 01/02/2012 it gives following error..
##Error Message
Not a number: 01/02/2012
Please use "." as decimal separator and "," as thousands separator??(#,###.##).
But for test when I entered 40015 as date value it shows correct corresponding date.
Anyone had issue before please tell me how to resolve it...
We are on TM1 ver 9.5.1
Lav
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: TM1 Web Date Format
Post by rkaif »
There is a PMR related to this issue.
http://www-304.ibm.com/support/docview. ... wg1PM24820
Cheers!
Rizwan Kaif
lav4you
Post by lav4you »
Hi Rizwan,
Thanks for the quick reply.
I went through the PMR. but not possible to upgrade ryt now.
Anyother possible solution?? any fix of work around..
Note:- Please dont say string.. :x I dont want to redo the rules again.
regards,
Lav
