01. 2 new text attributes added to a dimension
02. an unrelated requirement to replace files in data directory from previous day backup
03. [server restarted with backed up data dir]
04. ...
05. the 2 attributes are subsequently added back
06. attrs() in t.i. and =dbra() in worksheet can't read from those 2 attributes
07. ?!?
08. the 2 attributes are deleted
09. the same 2 attributes are added again
10. attrs() and =dbra() on the exact same attributes now start to work
11. [no }ElementAttributes_ unloaded or server bounce involved after the restart]
only theory i have is that it was conflicting with the attribute names which were replaced by
the file replace in data directory, then where would it store that info
I have had this one before. It retains the text attribute setting in cached memory. The only way I have found to solve this issue is to restart the service. If you do a search you'll probably find a post already covering this issue,
Struggling through the quagmire of life to reach the other side of who knows where. Go Build a PC Jimbo PC Builds on YouTube OS: Mac OS 11 PA Version: 2.0.7
