Determine Direct Element Ancestor From Element
youngjedi
Version: 9.5 - 10.1
Excel Version: Microsoft Excel 2010
Post by youngjedi »
I have a list of zero level elements from a TM1 dim in Excel in column A. In column B, I would like to return the direct parent of the element in column A. What is the function to d this???
Thanks.
Re: Determine Direct Element Ancestor From Element
youngjedi wrote: I have a list of zero level elements from a TM1 dim in Excel in column A. In column B, I would like to return the direct parent of the element in column A. What is the function to d this???
A parent is an ancestor, but an ancestor may not be a parent of a given element.
Assuming that it's a parent (especially as you said "direct" element ancestor), it would be ELPAR(dimension, element, index).
Refer to the Reference Guide for a full list of functions.
