I have a customer who wants TM1 but quite simply is priced out of the market, obvious next step was to just build the model in CX Xcelerator.
The questions revolves around what is and is not allowed in regards to data imports, since IBM have basically packaged a product with all the functionality of TM1 but said that you are not allowed to use certain parts or you will get your wrists slapped... this being proven by the fact I am certain you are NOT ALLOWED to import data directly from "full fat" BI yet a little bit of testing proved it is still possible... they didn't even hit it hard enough to actually remove the functionality
What are the ways that are considered acceptable for data imports from source systems?
I would make a safe assumption that a good old fashioned import everything from a flat file should never provide legal issues (fingers crossed.)
Can I still just query directly from a SQL table?
Are there any other huge omissions in general that I should be aware of before progressing down the CX route?
I have read other posts on the forum and I have also spoken with IBM directly (possibly the cause of the confusion)... there seems to be a lot of contradictory opinions and info available in general.
My basic idea:
100 users max
1 instance only
No direct connection to BI
Its always going to be the prior version to TM1 (not that we have seen any huge leaps in functionality in a while... apart from autofeeders <shudders>)
There must be something else wrong with it though when the difference in price equates to something in comparison of a Ford Focus vs a Bugatti Veyron!
