OR in if statement in TI
jcblough
Post by jcblough »
does this exist, I have the following statement:
['Forecast', '06XW'] =N: IF(('ESP Sales' @= !SSP_m), Continue, 0);
It is zeroing out values for an entire level of a cube sans the measure 'ESP Sales' I want it to leave ESP Sales and another value, is there a proper 'or' structure? "OR", '|', and '||' do not work.
Re: OR in if statement in TI
Do a search for "tm1 logical operators"
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
jcblough wrote:does this exist, I have the following statement:
The OR operator is represented by "%".
But in your case you could change the rule to:
['Forecast', '06XW', {'ESP Sales', 'another value'}] =N: 0;
Michel
jim wood
Version: PA 2.0.7
Post by jim wood »
Indeed. They can found in the reference guide.
jcblough
Post by jcblough »
Thanks, I've seen alot of things, but "%" for OR is a new one.
jim wood wrote:Indeed. They can found in the reference guide.
And a link to that section of the guide was included under the "Frequently Referenced Sections" heading of the FAQ.
jim wood
Version: PA 2.0.7
Post by jim wood »
A link can also be found under the help menu with Architect / Server Explorer. Spoilt for choice really!!! :D
(Not to forget the PDF version in doc library.)
