Found which Tm1 servers are working
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Post by EP_explorer »
Is possible using TI commands (or by another way) found which TM1 servers are working in current moment at host?
Re: Found which Tm1 servers are working
Post by David Usherwood »
Suggest you look at using Powershell, on the lines of
get-service -name tm1
David Usherwood wrote:Suggest you look at using Powershell, on the lines of
I wouldn't trust just knowing that the service was running, what if the server is "up" but non-responsive? If there really truly was a need for it (and that's a decent sized if) then I'd be inclined to either
- have an app that routinely logs in, retrieves a known view and logs out and informs if there is a hang on log in or wait on view retrieval
- have an app that monitors a top log output and informs if there are ever > x threads in wait status for > x seconds
- ask a certain Mr B Hill if he would add such a monitoring tool to his CubeSpy application
rmackenzie
Post by rmackenzie »
EP_explorer wrote:Is possible using TI commands (or by another way) found which TM1 servers are working in current moment at host?
Just create a new process and put this in the Prolog:
# turn off quoting
DatasourceASCIIQuoteCharacter = '';
# set up file names
sDataDirectoryPath = 'C:\YOUR\TM1\DATA\DIRECTORY\';
sOutputFileName = 'current_instances.txt';
sFullOutputFileName = '"' | sDataDirectoryPath  | sOutputFileName | '"';
# this does the work
sCommand = 'tasklist /svc /fi "imagename eq tm1sd.exe" /fo csv > ' | sFullOutputFileName ;
# run the batch
sBatchFileName = sDataDirectoryPath | 'get_current_instances.bat';
AsciiOutput ( sBatchFileName, sCommand );
ExecuteCommand ( sBatchFileName, 1 );
# now pass this file back to TM1
#ExecuteProcess ( 'YOUR_PROCESS', 'pTM1InstanceFileName', sFullOutputFileName );
That works for me, how about you? The CSV will be easily readable by another TM1 process that you can write to work through the file and do something with the information.
Robin Mackenzie
rmackenzie
lotsaram wrote:I wouldn't trust just knowing that the service was running, what if the server is "up" but non-responsive?
The output from the command (used in the code I posted) includes the PID (process identifier):
You can also run this command using /v for verbose output (drop the /svc):
tasklist /v /fi "imagename eq tm1sd.exe" /fo csv
Which will give the current memory usage, cpu time and 'status' by PID. You can then 'join' on PID and find out the current memory usage and CPU time per TM1 instance directly from TI. On my machine, 'status' is always unknown, but monitoring deltas in CPU time should show 'responsiveness'.
Actually, you can start to get a bit clever and say:
tasklist /svc /fi "imagename eq tm1sd.exe" /fi "memusage gt 20000000" /fo csv
Which says 'give me every TM1 instance where memory usage is currently above 20Gb'.
More information available here.
YMMV
Robin Mackenzie
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Thank you for answers
