The rule is a simple one:
['Actuals', '81500'] = N: Stet;
['81500'] = N: ['81010'];Code: Select all
['81010']=> ['81500'];However when my assistant took the rules out... 81500 retained the original value from 81010. When you right click on the value it no longer shows Trace Calculation as an option, it can be edited, naturally... yet the value of 81010 still appears in 81500's cell.
This doesn't occur in 9.1 SP4; there if you delete the rule, the value goes away. Add the rule back, it reappears. Comment out the rule, it goes away and so on.
But in 8.2.12, the only way you can get rid of the value is by manually obliterating it.
Does anyone remember encountering this behaviour and / or when it was fixed?
