String element will only take Number
LeeTaylor1979
OLAP Product: IBM Cognos TM1
Post by LeeTaylor1979 »
I have set up an String element in a Calendar Dimension called Description.
I would like users to type in ant text they need to but for some reason it will only accept Numbers.
There are rules calculating different currencies, but I have made my Description element STET but still no good.
Has anyone got any ideas please ?
Lee
Re: String element will only take Number
For an element to be treated as string it needs to be in the last dimension of the cube.
So if your fourth dimension is your measure dim and contains strings and numbers and your fifth contains all numbers then this will override your fourth.
If thats not it then not sure!
LeeTaylor1979
Steve,
I did not know that.
Problem solved as it always is when posted on this forum.
Many thanks
Lee
