I am obliged if any one could guide me the steps in using a PL/SQL in TI process, if possible.
Thanks in advance.
Is there any way to use PL/SQL Procedure in TM1 TI Process.
ryan
- OLAP Product: COGNOS
- Version: 9.0
Configuration Details
Microsoft Window Server 2003 Exterprise x64 Edition Service Pack 2
RAM 32 GB
using IBM Cognos Express Xcelerator (Version 10.1)
MS-Office Excel 2010 (12.0.6514.5000)SP2 MSO (12.0.6425.1000)
Microsoft .NET Framework 3.5
RAM 32 GB
Re: Is there any way to use PL/SQL in TM1 TI Process.
- Read the manuals - specifically the TI Manual on importing from an ODBC source and the TI 'Tutorial'
- Setup an ODBC environment for Oracle on the TM1 server and make sure you can connect and query
(Need to use a System DSN) - Create a TI, select ODBC, select DSN, write query
- Deal with the data coming back to fit your requirement
