Interaction between Cognos 8 and TM1 Contributor
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Post by EP_explorer »
I'm trying to integrate Cognos 8 and TM1 Contributor 9.5 and one problem happened
I have no problems when I'm connecting through http://servername:8080/pmpsvc
I see page with login, password from Cognos 8 - input them and see my TM1 applications
but I have another sort of problem
I don't see folder with TM1 application in Cognos 8 portal
I copied files in their destination (as described in the instruction), added
var planningServices = ["http://server-name:8080"]; in planning.html
but anyway I don't see folder with TM1 application in Cognos 8 portal
I remember some time ago I did it in another server and there was that folder but now It seems I forget something to do or did something wrong
Can somebody help?
skinners666
Version: 9.5.2
Excel Version: 10.0
Re: Interaction between Cognos 8 and TM1 Contributor
Post by skinners666 »
Did you deploy the tm1 files to the cognos 8 gateway? see
http://publib.boulder.ibm.com/infocente ... teg_C89005
EP_explorer
OLAP Product: PAL
Version: 2.0.9
skinners666 wrote:Did you deploy the tm1 files to the cognos 8 gateway? see
Yes I did that is written here
skinners666
Version: 9.5.2
Excel Version: 10.0
I think the portal folders get created when you deploy the contributor apps - have you deployed the apps since youve set up the C8 integration? ie I dont think the folders appear until you have deployed again.
EP_explorer
OLAP Product: PAL
Version: 2.0.9
skinners666 wrote:I think the portal folders get created when you deploy the contributor apps - have you deployed the apps since youve set up the C8 integration? ie I dont think the folders appear until you have deployed again.
Thank you for answer. You were right. When I created new Contributor application folder with the application appeared in Cognos 8 portal.
