I have the following lines for a rule & feeder that works majority of the time. There are times when the previous period ending balance does not equal the current period beginning balance. When I do a "Check Feeders", it will return a value "not fed". Thanks in advance.
###Calculate Beginning Balance
['Beginning Balance']=N:
DB('TURNOVER',!campus,!dept,!job_codes,ATTRS('Periods',!periods,'Previous_Period'),!benefits,!status,'Ending Balance');
feeders;
['Ending Balance'] => ['Beginning Balance'];
Not Fed
Re: Not Fed
Your rule is taking data from the previous period, so your feeder should feed to the next period.
You've been a bit lucky in that you probably had data in most periods to make your incorrect feeder work.
RLReyes
- Version: 10.1.1
Re: Not Fed
David - If it's an incorrect feeder, what do you suggest I use as a feeder?David Usherwood wrote:You've been a bit lucky in that you probably had data in most periods to make your incorrect feeder work.
- Rod
TM1 Version: 10.1.1
Excel: 2010
TM1 Version: 10.1.1
Excel: 2010
- mce
- Version: Planning Analytics Local 2.0.x
- Excel Version: 2013 2016
Re: Not Fed
feeders;
['Ending Balance'] => DB('TURNOVER',!campus,!dept,!job_codes,ATTRS('Periods',!periods,'Next_Period'),!benefits,!status,'Beginning Balance');
AnthonyT
- OLAP Product: TM1, EV
- Version: 9.0 9.1 9.4 9.5 10.1 10.2
- Excel Version: 2003 2007 2010 2015
Re: Not Fed
Providing that you have a "Next Period" attribute on the Periods dimension
Anthony
That's no moon - that's a space station
Re: Not Fed
If you have any sort of financial or forecasting model that requires this kind of logic then you should have BOTH a "last period" AND a "next period" attribute end of story. Or in cases where models have a separate year and period dimension then better still a lookup string cube to store this. (Actually I wouldn't stop there but would typically have -13 to +13 offsets for year and month). To not have this is simply bad design.AnthonyT wrote:Providing that you have a "Next Period" attribute on the Periods dimension
Perhaps "bad design" is too strong maybe incompletely thought out, ill thought out or inexperienced would be more appropriate...
The amount of times I have audited a model to see all kinds of complicated combinations of STR, NUMBR, SCAN, SUBST to perform time shifts when a simple ATTRS or DB lookup would suffice (and be much more efficient in terms of calculation overhead) really makes me grind my teeth.
ram123
- Version: 10.1
Re: Not Fed
...Or in cases where models have a separate year and period dimension then better still a lookup string cube to store this. (Actually I wouldn't stop there but would typically have -13 to +13 offsets for year and month). To not have this is simply bad designI don't think there is a need to write 13 feeders (for ex: dimnm(<dimname>, dimix(<dimname>,(!<dimname>)+1).. +2, +3...so on..)
I do not have the ATTRS/ATTRN (for 'Prev Period and 'Next Period') in my model.
Help appreciated!
