Read Folder Name Using TI
mariatjahjadi
OLAP Product: sql
Version: tm1 9.5
Post by mariatjahjadi »
Dear All,
I am developing TM1 and using TI as ETL tools.
Could someone tell me how to read folder name using TI?
I need to access a file inside the folder, and need to determine who is the owner of the file based on the folder name.
I can do it with SSIS, but have no clue how to do that using TI.
Thanks.
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Read Folder Name Using TI
Post by Duncan P »
I am a little confused here. How is it that the file is being specified if not by a path?
If there is a path then it will be possible to crack it open using the SCAN and SUBST rule functions that also work in TI.
rmackenzie
Post by rmackenzie »
Often, with TM1, you just have to write something yourself:
sPath='c:\test\this\folder name\whatever.txt';
# get the string between the last and second last \
nCounter=LONG(sPath);
nContinue=1;
nFoundFirstBackslash=0;
sFolderName='';
WHILE(nContinue=1&nCounter>0);
  sChar=SUBST(sPath,nCounter,1);
  IF(nFoundFirstBackslash=1&sChar@<>'\');
    sFolderName=sChar|sFolderName;
  ENDIF;
  IF(sChar@='\');
    IF(nFoundFirstBackSlash=1);
      nContinue=0;
    ELSE;
      nFoundFirstBackSlash=1;
    ENDIF;
  ENDIF;
  nCounter=nCounter-1;
END;
# test parse output
AsciiOutput('test_parse.txt',sFolderName);
Robin Mackenzie
