We have been an issue of late on a particular TM1 Service. We are running 9.5.2 and everynight we have a Stop Service, Backup Service, Start Service routine running which does what it says on the Tin. It has been working fine for a number of months (if not years!).
However a few days ago one of the Services didnt Stop properly and continues not to stop properly everynight. (The Stop service command is ran from a BAT Script which is executed from Scheduled Tasks)
The following is in the Server Logs, there are other Chores which it never actually gets round to deactivating and the server shut down message never appears in the Logs.
At this point the Server cannot be access via the Client or TM1Top, but the Service continues to kick off a couple of chores which we run on the service every hour, and the chores will continue to be kicked off until the Service is killed off via Task manager.
In Windows Services it still shows it as Stopping, and the only way to get it started properly is to kill the task first and Start again.
Nothing has changed in the model, i.e. no rule changes, No abnormal structural changes etc.
Anyone else come across a similiar issue, or can anyone hazard a guess as to a probably cause?
Thanks in advance
4636 [] INFO 2011-11-26 00:38:05.603 TM1.Server Closing...
4636 [] INFO 2011-11-26 00:38:05.603 TM1.Server Saving...
4636 [] INFO 2011-11-26 00:38:05.603 TM1.Server The server is coming down...
5792 [] INFO 2011-11-26 00:38:05.603 TM1.Server Terminating housekeeper thread.
4636 [] INFO 2011-11-26 00:38:05.806 TM1.Chore Deactivating chore: Count User Daily Transfer
4636 [] INFO 2011-11-26 00:38:09.712 TM1.Chore Deactivating chore: Count User Load xx20
4636 [] INFO 2011-11-26 00:38:12.541 TM1.Chore Deactivating chore: Count User Load xx50
4636 [] INFO 2011-11-26 00:38:16.869 TM1.Chore Deactivating chore: Export Master CSR Contract List
4636 [] INFO 2011-11-26 00:38:19.729 TM1.Chore Deactivating chore: Purge Postscript Directory
4636 [] INFO 2011-11-26 00:38:24.714 TM1.Chore Deactivating chore: Refresh Subsets
4636 [] INFO 2011-11-26 00:38:26.870 TM1.Chore Deactivating chore: Set Current Period to Actualisation Status Cube
