Getting TM! Perspectives 9.5.2 to work with Citrix
burkemg
Version: 9.5.2
Excel Version: 2003+2007+2010
Post by burkemg »
Have just got TM1 Perspectives ver 9.5.2 to load with Excell 2003 under Citrix, in server explorer can see the server but the server select interface hangs on selecting a server Any ideas or recommendations on what the issue might be?
All suggestions welcome
qml
Excel Version: 2007 - 2016
Re: Getting TM! Perspectives 9.5.2 to work with Citrix
Post by qml »
Martin Ryan wrote:In order to ensure this forum is as useful as possible only administrators will be allowed to begin new topics.
I think something went wrong there...
burkemg, such threads should be posted in the main Cognos TM1 subforum.
Kamil Arendt
I've moved it. Martin's post indicated how things were, but the Useful Code, Tips and Tricks forum was opened up to allow people to post relating to Bedrock... of which there has been nothing to date, but that's neither here nor there. I'll leave Martin to tweak it since it's his post.
Normally one of the admins will sweep stuff that goes into the wrong forum into the correct one in due course.
moby91
Version: 9.5.1
Excel Version: 2003 2007
Post by moby91 »
How many TM1 server instances do you have ?
How many TM1 server instances are displayed in the TM1 Server Explorer ?
One ?
Two or more ?
In the TM1 server configuration file tm1s.cfg of each of your TM1 server instances, did you set the parameter ClientMessagePortNumber ?
And is the value of the parameter ClientMessagePortNumber unique ?
burkemg
Version: 9.5.2
Post by burkemg »
The Citrix team managed to resolve the issue can see the Server now TM1 9.5.2 on Win 2008 64 bitv version
We have two test instances Sample and a copy of Production
The issue now is the slowness of Tm1 perspectives using our production copy via Excel 2003 in Citrix
Any suggestions as to where to start looking?
qml
Post by qml »
Care to post how your Citrix team solved it?
If there are performance issues in Citrix the first thing to check would be the speed and quality of network connection between the physical TM1 box and the physical Citrix XenApp server box. Basically you want both to be as close to each other as possible with a really fast network connection.
Kamil Arendt
Paul Segal
Version: TM1 11 and up
Post by Paul Segal »
When you say Citrix what do you mean exactly? Can you give us the product name and version? When you say "slow", can you also be a little more specific?
Paul
